Hello all,
I am currently struggling with getting my Aotec TriSensor to report values into openhab. I am using the following:
- Ubuntu 18.04 virtual machine
- Java 11
- Latest version of Openhab
- Aotec zstick 5
- Aotec TriSensor
I am trying to connect the sensor to openhab using what i understand to be a fairly regular methodology. First, i install the z-wave binding (https://www.openhab.org/addons/bindings/zwave/). Next, i go to my inbox and add the zstick as a thing, making sure to select the correct usb port (/dev/ttyACM0). I know this step works as it appears online within openhab. After that, i go back to my inbox and search for zwave devices, a process in which the Aotec TriSensor does appear and allow me to add it as a thing. This then populates the necessary channels for me (temp, battery, light, motion) and i create/add some new items to those channels so i can see any information i receive in the control section.
After completing the aforementioned steps i would have assumed that everything is fine, as the openhab and event logs don’t show anything untoward, however all the values perpetually stay at NaN or just blank, and the ui doesn’t even register that the sensor has gone offline if i take the battery out of it.
Logs:
Events
2020-02-20 11:54:07.747 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2020-02-20 12:05:47.577 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:05:47.653 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:1a71c6d5' has been updated.
2020-02-20 12:05:47.674 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:05:56.796 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:05:56.807 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:1a71c6d5' has been updated.
2020-02-20 12:06:19.007 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:1a71c6d5:node5' has been added.
2020-02-20 12:06:19.043 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:1a71c6d5:node6' has been added.
2020-02-20 12:06:38.415 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:1a71c6d5:node6' has been removed.
2020-02-20 12:06:40.582 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:1a71c6d5:node5' has been removed.
2020-02-20 12:07:54.584 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist
2020-02-20 12:08:29.517 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to ONLINE
2020-02-20 12:08:29.526 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:1a71c6d5' has been updated.
2020-02-20 12:08:33.645 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from ONLINE to REMOVING
2020-02-20 12:08:33.666 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from REMOVING to REMOVED
2020-02-20 12:08:33.728 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from REMOVED to UNINITIALIZED
2020-02-20 12:08:33.859 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:1a71c6d5' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:09:27.647 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:09:27.697 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:66de4257' has been updated.
2020-02-20 12:09:27.705 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:11:51.495 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to REMOVING
2020-02-20 12:11:51.512 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from REMOVING to REMOVED
2020-02-20 12:11:51.545 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from REMOVED to UNINITIALIZED
2020-02-20 12:11:52.057 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:66de4257' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:12:48.331 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:12:48.356 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:12:48.367 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:12:57.416 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:12:57.447 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:15:28.309 [home.event.InboxAddedEvent] - Discovery Result with UID 'zwave:device:f3448e9b:node2' has been added.
2020-02-20 12:15:36.456 [me.event.InboxRemovedEvent] - Discovery Result with UID 'zwave:device:f3448e9b:node2' has been removed.
2020-02-20 12:15:36.531 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:15:36.555 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:15:36.588 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2020-02-20 12:15:36.652 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:15:36.718 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2020-02-20 12:15:36.728 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:15:36.766 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:15:36.771 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:15:36.772 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:15:36.779 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:15:36.787 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:15:36.861 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[]]
2020-02-20 12:15:36.988 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:17:38.360 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode002_SensorTemperature-zwave:device:f3448e9b:node2:sensor_temperature' has been added.
2020-02-20 12:18:04.305 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode002_SensorLuminance-zwave:device:f3448e9b:node2:sensor_luminance' has been added.
2020-02-20 12:18:14.801 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode002_MotionAlarm-zwave:device:f3448e9b:node2:alarm_motion' has been added.
2020-02-20 12:18:25.987 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode002_BatteryLevel-zwave:device:f3448e9b:node2:battery-level' has been added.
2020-02-20 12:21:24.914 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:24.953 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:24.959 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:24.975 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:24.990 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:25.003 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:25.009 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:25.024 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:25.034 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:25.046 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:25.054 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:25.066 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:25.103 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:25.125 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:25.131 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:26.397 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:27.016 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:21:27.024 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from UNINITIALIZED to ONLINE
2020-02-20 12:21:27.032 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from ONLINE to OFFLINE
2020-02-20 12:21:27.053 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:21:27.641 [temChannelLinkRemovedEvent] - Link 'WindowSensor_W => mqtt:topic:5aa31257:window' has been removed.
2020-02-20 12:21:27.655 [temChannelLinkRemovedEvent] - Link 'Test_Item_1 => mqtt:topic:dbbe88fc:test-thing-1-text' has been removed.
2020-02-20 12:21:27.656 [temChannelLinkRemovedEvent] - Link 'GlassBreakSensor => mqtt:topic:562dccd3:glass_break_sensor' has been removed.
2020-02-20 12:21:27.662 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_BatteryLevel => zwave:device:f3448e9b:node2:battery-level' has been removed.
2020-02-20 12:21:27.664 [temChannelLinkRemovedEvent] - Link 'WindowSensor => mqtt:topic:5aa31257:t' has been removed.
2020-02-20 12:21:27.672 [temChannelLinkRemovedEvent] - Link 'DoorLock => mqtt:topic:0d81385e:door_lock' has been removed.
2020-02-20 12:21:27.687 [temChannelLinkRemovedEvent] - Link 'Test_Item_2 => mqtt:topic:be045d4a:test_thing_2' has been removed.
2020-02-20 12:21:27.691 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_MotionAlarm => zwave:device:f3448e9b:node2:alarm_motion' has been removed.
2020-02-20 12:21:27.701 [temChannelLinkRemovedEvent] - Link 'MotionSensor => mqtt:topic:75f9a474:motion_sensor' has been removed.
2020-02-20 12:21:27.707 [temChannelLinkRemovedEvent] - Link 'TemperatureSensor_Ts => mqtt:topic:fe331cb3:temperature_sensor' has been removed.
2020-02-20 12:21:27.711 [temChannelLinkRemovedEvent] - Link 'PleaseWork_1 => mqtt:topic:25047df4:1' has been removed.
2020-02-20 12:21:27.713 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_SensorTemperature => zwave:device:f3448e9b:node2:sensor_temperature' has been removed.
2020-02-20 12:21:27.731 [temChannelLinkRemovedEvent] - Link 'DoorSensor => mqtt:topic:ac984435:door_sensor' has been removed.
2020-02-20 12:21:27.759 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_SensorLuminance => zwave:device:f3448e9b:node2:sensor_luminance' has been removed.
2020-02-20 12:22:08.815 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:08.968 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from INITIALIZING to OFFLINE
2020-02-20 12:22:10.387 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from OFFLINE to ONLINE
2020-02-20 12:22:10.424 [me.event.ThingUpdatedEvent] - Thing 'mqtt:broker:82cd2be3' has been updated.
2020-02-20 12:22:11.267 [vent.ItemStateChangedEvent] - DoorLock changed from NULL to door_secured
2020-02-20 12:22:11.291 [vent.ItemStateChangedEvent] - WindowSensor_W changed from NULL to CLOSED
2020-02-20 12:22:11.305 [vent.ItemStateChangedEvent] - GlassBreakSensor changed from NULL to no_event
2020-02-20 12:22:11.314 [vent.ItemStateChangedEvent] - MotionSensor changed from NULL to no_event
2020-02-20 12:22:11.365 [vent.ItemStateChangedEvent] - DoorSensor changed from NULL to CLOSED
2020-02-20 12:22:11.447 [vent.ItemStateChangedEvent] - TemperatureSensor_Ts changed from NULL to 20.000418 °C
2020-02-20 12:22:12.215 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.366 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from INITIALIZING to ONLINE
2020-02-20 12:22:12.382 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.393 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from INITIALIZING to ONLINE
2020-02-20 12:22:12.398 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.407 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from INITIALIZING to ONLINE
2020-02-20 12:22:12.422 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.435 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from INITIALIZING to ONLINE
2020-02-20 12:22:12.448 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.499 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from INITIALIZING to ONLINE
2020-02-20 12:22:12.509 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:12.517 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from INITIALIZING to ONLINE
2020-02-20 12:22:15.254 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-02-20 12:22:15.950 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:22:15.962 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:22:16.011 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-02-20 12:22:16.020 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:22:25.993 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:22:26.022 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:22:26.042 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:22:26.103 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:23:19.069 [ome.event.ItemUpdatedEvent] - Item 'ZWaveNode002_SensorTemperature' has been updated.
2020-02-20 12:24:21.871 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_SensorTemperature => zwave:device:f3448e9b:node2:sensor_temperature' has been removed.
2020-02-20 12:24:28.480 [ome.event.ItemUpdatedEvent] - Item 'ZWaveNode002_SensorTemperature' has been updated.
2020-02-20 12:24:28.805 [.ItemChannelLinkAddedEvent] - Link 'ZWaveNode002_SensorTemperature-zwave:device:f3448e9b:node2:sensor_temperature' has been added.
2020-02-20 12:26:17.535 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:26:17.788 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:17.812 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:26.606 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:26:26.609 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:26:26.618 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:26:26.628 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:26:26.647 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-02-20 12:26:43.562 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:43.571 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:43.597 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:26:53.245 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:26:53.253 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:26:53.275 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:26:53.311 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2020-02-20 12:26:56.890 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:56.898 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE: Node initialising: REQUEST_NIF to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:26:56.924 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:27:05.982 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:27:05.985 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:27:06.002 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:27:06.019 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:34:29.382 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:34:29.457 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=wakeup_node, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=wakeup_interval, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2020-02-20 12:37:35.969 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:37:35.992 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=wakeup_node, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=wakeup_interval, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2020-02-20 12:38:41.765 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:38:41.802 [vent.ConfigStatusInfoEvent] - ConfigStatusInfo [configStatusMessages=[ConfigStatusMessage [parameterName=wakeup_node, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null], ConfigStatusMessage [parameterName=wakeup_interval, type=PENDING, messageKey=null, arguments=null, message=null, statusCode=null]]]
2020-02-20 12:40:14.926 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:40:15.300 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:40:15.311 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:45:54.879 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist
2020-02-20 12:47:48.386 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.452 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.459 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.491 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.494 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.510 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.523 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.540 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.551 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.576 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.582 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:48.615 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.687 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to UNINITIALIZED
2020-02-20 12:47:48.708 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:48.724 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to UNINITIALIZED
2020-02-20 12:47:48.756 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:49.428 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from ONLINE to UNINITIALIZED
2020-02-20 12:47:49.537 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from UNINITIALIZED to ONLINE
2020-02-20 12:47:49.560 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from ONLINE to OFFLINE
2020-02-20 12:47:49.576 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from OFFLINE to UNINITIALIZED (HANDLER_MISSING_ERROR)
2020-02-20 12:47:50.227 [temChannelLinkRemovedEvent] - Link 'WindowSensor_W => mqtt:topic:5aa31257:window' has been removed.
2020-02-20 12:47:50.228 [temChannelLinkRemovedEvent] - Link 'Test_Item_1 => mqtt:topic:dbbe88fc:test-thing-1-text' has been removed.
2020-02-20 12:47:50.228 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_BatteryLevel => zwave:device:f3448e9b:node2:battery-level' has been removed.
2020-02-20 12:47:50.228 [temChannelLinkRemovedEvent] - Link 'GlassBreakSensor => mqtt:topic:562dccd3:glass_break_sensor' has been removed.
2020-02-20 12:47:50.228 [temChannelLinkRemovedEvent] - Link 'WindowSensor => mqtt:topic:5aa31257:t' has been removed.
2020-02-20 12:47:50.229 [temChannelLinkRemovedEvent] - Link 'DoorLock => mqtt:topic:0d81385e:door_lock' has been removed.
2020-02-20 12:47:50.229 [temChannelLinkRemovedEvent] - Link 'Test_Item_2 => mqtt:topic:be045d4a:test_thing_2' has been removed.
2020-02-20 12:47:50.229 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_MotionAlarm => zwave:device:f3448e9b:node2:alarm_motion' has been removed.
2020-02-20 12:47:50.229 [temChannelLinkRemovedEvent] - Link 'MotionSensor => mqtt:topic:75f9a474:motion_sensor' has been removed.
2020-02-20 12:47:50.229 [temChannelLinkRemovedEvent] - Link 'TemperatureSensor_Ts => mqtt:topic:fe331cb3:temperature_sensor' has been removed.
2020-02-20 12:47:50.253 [temChannelLinkRemovedEvent] - Link 'PleaseWork_1 => mqtt:topic:25047df4:1' has been removed.
2020-02-20 12:47:50.265 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_SensorTemperature => zwave:device:f3448e9b:node2:sensor_temperature' has been removed.
2020-02-20 12:47:50.278 [temChannelLinkRemovedEvent] - Link 'DoorSensor => mqtt:topic:ac984435:door_sensor' has been removed.
2020-02-20 12:47:50.286 [temChannelLinkRemovedEvent] - Link 'ZWaveNode002_SensorLuminance => zwave:device:f3448e9b:node2:sensor_luminance' has been removed.
2020-02-20 12:48:37.804 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:37.909 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from INITIALIZING to OFFLINE
2020-02-20 12:48:39.323 [hingStatusInfoChangedEvent] - 'mqtt:broker:82cd2be3' changed from OFFLINE to ONLINE
2020-02-20 12:48:39.343 [me.event.ThingUpdatedEvent] - Thing 'mqtt:broker:82cd2be3' has been updated.
2020-02-20 12:48:40.148 [vent.ItemStateChangedEvent] - DoorLock changed from NULL to door_secured
2020-02-20 12:48:40.166 [vent.ItemStateChangedEvent] - WindowSensor_W changed from NULL to CLOSED
2020-02-20 12:48:40.175 [vent.ItemStateChangedEvent] - GlassBreakSensor changed from NULL to no_event
2020-02-20 12:48:40.186 [vent.ItemStateChangedEvent] - MotionSensor changed from NULL to no_event
2020-02-20 12:48:40.236 [vent.ItemStateChangedEvent] - DoorSensor changed from NULL to CLOSED
2020-02-20 12:48:40.298 [vent.ItemStateChangedEvent] - TemperatureSensor_Ts changed from NULL to 20.000418 °C
2020-02-20 12:48:40.880 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.052 [hingStatusInfoChangedEvent] - 'mqtt:topic:562dccd3' changed from INITIALIZING to ONLINE
2020-02-20 12:48:41.067 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.069 [hingStatusInfoChangedEvent] - 'mqtt:topic:0d81385e' changed from INITIALIZING to ONLINE
2020-02-20 12:48:41.078 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.084 [hingStatusInfoChangedEvent] - 'mqtt:topic:75f9a474' changed from INITIALIZING to ONLINE
2020-02-20 12:48:41.098 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.110 [hingStatusInfoChangedEvent] - 'mqtt:topic:fe331cb3' changed from INITIALIZING to ONLINE
2020-02-20 12:48:41.127 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.136 [hingStatusInfoChangedEvent] - 'mqtt:topic:ac984435' changed from INITIALIZING to ONLINE
2020-02-20 12:48:41.144 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:41.165 [hingStatusInfoChangedEvent] - 'mqtt:topic:5aa31257' changed from INITIALIZING to ONLINE
2020-02-20 12:48:44.459 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2020-02-20 12:48:44.592 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from UNINITIALIZED to INITIALIZING
2020-02-20 12:48:44.617 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:48:44.684 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2020-02-20 12:48:44.715 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2020-02-20 12:48:49.679 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist
2020-02-20 12:49:27.719 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:f3448e9b' changed from OFFLINE (COMMUNICATION_ERROR): Serial Error: Port /dev/ttyACM0 does not exist to ONLINE
2020-02-20 12:49:27.767 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2020-02-20 12:49:27.803 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:f3448e9b:node2' has been updated.
2020-02-20 12:49:27.810 [me.event.ThingUpdatedEvent] - Thing 'zwave:serial_zstick:f3448e9b' has been updated.
2020-02-20 12:49:27.865 [hingStatusInfoChangedEvent] - 'zwave:device:f3448e9b:node2' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
Openhab
2020-02-20 12:05:52.889 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:05:52.890 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:06:18.974 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-02-20 12:06:19.015 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:1a71c6d5:node5' to inbox.
2020-02-20 12:06:19.023 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! Manufacturer data not known.
2020-02-20 12:06:19.051 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:1a71c6d5:node6' to inbox.
2020-02-20 12:08:24.644 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:08:24.647 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:09:27.575 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-02-20 12:09:32.763 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:09:32.767 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:12:48.238 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-02-20 12:12:53.697 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:12:53.698 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:15:28.308 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'zwave:device:f3448e9b:node2' to inbox.
2020-02-20 12:17:37.336 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorTemperature'.
2020-02-20 12:18:03.637 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorLuminance'.
2020-02-20 12:18:14.118 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_MotionAlarm'.
2020-02-20 12:18:25.297 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_BatteryLevel'.
2020-02-20 12:21:23.300 [WARN ] [org.jline ] - The Parser of class org.apache.karaf.shell.impl.console.ConsoleSessionImpl$$Lambda$908/0x0000000100f0d840 does not support the CompletingParsedLine interface. Completion with escaped or quoted words won't work correctly.
2020-02-20 12:21:24.824 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@3a3b82af from discovery topic homeassistant/# on broker mqtt:broker:82cd2be3 but topic not registered for listener. Check discovery logic!
2020-02-20 12:21:24.869 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7b95542c from discovery topic +/+/$homie on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:21:24.871 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7b95542c from discovery topic homeassistant/# on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:21:24.873 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7b95542c from discovery topic +/+/$homie on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:21:27.139 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2020-02-20 12:21:27.162 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2020-02-20 12:21:27.184 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-02-20 12:21:27.212 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-02-20 12:21:27.280 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2020-02-20 12:22:03.157 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2020-02-20 12:22:06.357 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-02-20 12:22:07.427 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.252.130:666
2020-02-20 12:22:07.434 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.252.130:6666
2020-02-20 12:22:08.183 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-20 12:22:08.279 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-02-20 12:22:08.390 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-02-20 12:22:10.158 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.252.130' with clientid fa2dc393-bc50-42dd-a3fd-194b42b3f74f
2020-02-20 12:22:11.278 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_BatteryLevel'.
2020-02-20 12:22:11.317 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'WindowSensor'.
2020-02-20 12:22:11.328 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'Test_Item_2'.
2020-02-20 12:22:11.333 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorLuminance'.
2020-02-20 12:22:11.341 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'Test_Item_1'.
2020-02-20 12:22:11.346 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_MotionAlarm'.
2020-02-20 12:22:11.368 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorTemperature'.
2020-02-20 12:22:15.264 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-02-20 12:22:21.665 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:22:21.667 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:23:19.045 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorTemperature'.
2020-02-20 12:24:28.472 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorTemperature'.
2020-02-20 12:26:22.862 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:26:22.864 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:26:49.611 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:26:49.613 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:27:02.121 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:27:02.122 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:40:20.354 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:40:20.360 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:46:55.188 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:46:55.189 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2020-02-20 12:47:46.916 [WARN ] [org.jline ] - The Parser of class org.apache.karaf.shell.impl.console.ConsoleSessionImpl$$Lambda$853/0x0000000100e71440 does not support the CompletingParsedLine interface. Completion with escaped or quoted words won't work correctly.
2020-02-20 12:47:48.309 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homie.internal.discovery.Homie300Discovery@6016138f from discovery topic homeassistant/# on broker mqtt:broker:82cd2be3 but topic not registered for listener. Check discovery logic!
2020-02-20 12:47:48.359 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7fb8519e from discovery topic +/+/$homie on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:47:48.366 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7fb8519e from discovery topic homeassistant/# on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:47:48.368 [WARN ] [g.mqtt.handler.AbstractBrokerHandler] - Tried to unsubscribe org.openhab.binding.mqtt.homeassistant.internal.discovery.HomeAssistantDiscovery@7fb8519e from discovery topic +/+/$homie on broker mqtt:broker:82cd2be3 but topic not registered at all. Check discovery logic!
2020-02-20 12:47:49.668 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2020-02-20 12:47:49.692 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2020-02-20 12:47:49.706 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2020-02-20 12:47:49.760 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2020-02-20 12:47:49.821 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2020-02-20 12:48:32.754 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysql.persist'
2020-02-20 12:48:36.017 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-02-20 12:48:36.879 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.252.130:666
2020-02-20 12:48:36.880 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.252.130:6666
2020-02-20 12:48:37.382 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2020-02-20 12:48:37.463 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2020-02-20 12:48:37.539 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2020-02-20 12:48:39.087 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.252.130' with clientid 6f16bcef-a82f-4aa9-b5db-c0a6ab8e286f
2020-02-20 12:48:40.154 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_BatteryLevel'.
2020-02-20 12:48:40.189 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'WindowSensor'.
2020-02-20 12:48:40.197 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'Test_Item_2'.
2020-02-20 12:48:40.204 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorLuminance'.
2020-02-20 12:48:40.214 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'Test_Item_1'.
2020-02-20 12:48:40.219 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_MotionAlarm'.
2020-02-20 12:48:40.239 [ERROR] [sql.internal.MysqlPersistenceService] - mySQL: Unable to find table for query 'ZWaveNode002_SensorTemperature'.
2020-02-20 12:48:44.480 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2020-02-20 12:49:19.847 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2020-02-20 12:49:19.849 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
I’m at a loss of what to do here, as i don’t quite understand what is going wrong. I would assume that for some reason there is no communication between the stick and the sensor, leading to no updates to any values/states however i’m also not entirely sure how i can test/verify/fix this? If it helps at all, my zstick when plugged in continually changes between green, red, and blue lights without any change whatsoever. I have tried investigating if these are the correct colours to expect but i cannot find anything from aotec on this either.
I have tried factory resetting both the sensor and the stick multiple times, deleting them from openhab and readding them, etc to no avail. Thank you for taking the time to read this.
