Hello, I had a problem with my apache2 reverse proxy to openHAB since some times that I wanted to share.
When I enabled HTTP2 on my apache2 server the openhab web interface starts to behave strangely : everything shows normally but sometimes it takes several minutes. Trying to change an item results in : nothing happening.
Everything worked again flawlessly as soon as I added Protocols http/1.1
in the VirtualHost configuration.
My apache and openhab are on the same physical host by on different LXD containers.
Here is my complete VirtualHost config file :
<VirtualHost *:80>
ServerName my.host.com
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI}
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost *:443>
Protocols http/1.1
RequestHeader set X-Forwarded-Proto "https" env=HTTPS
ProxyPreserveHost on
LogLevel info warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
SSLCertificateFile /etc/letsencrypt/live/my.host.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/my.host.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/my.host.com/chain.pem
Include /etc/letsencrypt/options-ssl-apache.conf
ProxyPass / "http://10.10.125.70:8080/"
ProxyPassReverse / "http://10.10.125.70:8080/"
<Location />
AuthType Basic
AuthName "tony"
AuthUserFile /etc/apache2/htdigest_basic
Require valid-user
</Location>
</VirtualHost>
</IfModule>
Should I file a bug somewhere ? Is this issue already known ?
