The wiki doesn’t say anything about DELETE so I can’t say what it expects. I’ve only used the GET with the REST API so have little experience with the other verbs.
What docs are you looking at that list those lines?
Note that changing items (and adding deleting tags is a change as well) is only possible for items that are stored in the database (and thus are writable) and NOT for items from *.items files.
So if you add items through the REST API, you should also be able to PUT and DELETE tags on them.
Thanks for the replies @rlkoshak and @Kai. This particular set of docs is the live api documentation found by hitting the /doc URL. They are listed under items.
Kai, that is an important distinction that I missed. This is a 2.0 binding (Network to be exact) created through PaperUI, but the item definition is in a .items file. Is there any provision to alter tags statically in the items file? The entry looks like this:
Switch JimS5 [ "myTag1", "myTag2" ] { channel="network:device:141e3618:online" }
[quote="xsnrg, post:5, topic:1919"]
Alternately, if I remove the items file and use the API to create the item, then you are saying the tags can be manipulated, correct?
[/quote]
Correct!
