- Platform information:
Hardware:
LattePanda Alpha 864s
CPU:Intel 8th m3–8100y
Core:1.1-3.4GHz Dual-Core,Four-Thread
Graphics:Intel HD Graphics 615, 300-900MHz
RAM:8G LPDDR3
eMMC:64GB
External Memory: 1x M.2 M Key, PCIe 4x, NVMe SSD
Connectivity:WIFI 802.11 AC, 2.4G & 5G, Dual Band Bluetooth 4.2, Gigabyte Ethernet
USB Ports:3x USB 3.0 Type A / 1x USB Type C, supports PD, DP, USB 3.0
Display:HDMI Output / Type-C DP Support / Extendable eDP touch displays
Co-processor:Arduino Leonardo
GPIO & Other Features:2x 50p GPIOs including I2C, I2S, USB, RS232, UART, RTC,Power Management,Extendable power button -
OS: Ubuntu 20.04LTS
Java Runtime Environment: JDK 11 Zulu
openHAB version: 3.02
- Issue of the topic:
- I am using Postman to send API calls to the OH REST API
- GET works fine e.g. GET htp://latte01:8080/rest/items/DLight02_Color/state (proper state is returned)
- POST command also good e.g. POST http://latte01:8080/rest/items/DLight02 (with a body of “ON” in text/plain) Light turns on in the real world.
- State changes using PUT are not working as expected
- I can send a PUT e.g. PUT http://latte01:8080/rest/items/DLight02_Color/state (with a body of 0.0,0,100 in text/plain) to an Item to change state of a light and the state is changed (GET state returns the changed value)
- When this PUT is sent I can also see the relevant item state change correctly in the OH Admin UI (The Brightness slider in the UI moves to the 100 position)
- The problem is that the state change sent using the PUT does not actually change the state of the light in the real world. In my example I expect the light to turn on with a brightness of 100% but nothing actually happens
- Subsequent manual movement of the UI slider causes the light to come on
- I suspect I am being a real noobie here and would really appreciate some pointers as to what I am missing
Thanks Guys
Regards
Ian
