i´m trying configure my Aqara Cube Smart Home Controller.
My Setup:
- OH 2.4
- Deconz binding 2.5
Deconz things are configuerd and work fine. Now i created this rule, because it seems the Aquara Cube via Deconz has a different behavier to the rule described in the Xiaomi Mi Smart Home Binding.
I receive Numbers and no Events like “FLIP180”
rule "Aquara Magic Cube"
Channel "deconz:switch:Rpi-Phoscon-GW:MagicCube:buttonevent" triggered
var actionName = receivedEvent.getEvent()
switch(actionName) {
if actionName in [1000, 2000, 3000, 4000, 5000, 6000] {
logInfo(filename, "Magic Cube: slide")
} else if actionName in [1001, 2002, 3003, 4004, 5005, 6006] {
logInfo(filename, "Magic Cube: double tap")
} else if actionName in [1006, 2005, 3004, 4003, 5002, 6001] {
logInfo(filename, "Magic Cube: flip180")
} else if actionName in [1002, 1003, 1004, 1005, 2001, 2003, 2004, 2006, 3001, 3002, 3005, 3006, 4001, 4002, 4005, 4006, 5001, 5003, 5004, 5006, 6002, 6003, 6004, 6005] {
logInfo(filename, "Magic Cube: flip90")
} else if actionName == 7007 {
logInfo(filename, "Magic Cube: shake")
} else if actionName == 7008 {
logInfo(filename, "Magic Cube: free fall")
} else if actionName == 7000 {
logInfo(filename, "Magic Cube: wakeup")
I can see the event numbers in the OH log, but the rule is not fired.
Any ideas?
THX
