I have a new Aqara hub and try to read out the developer key for integrating to my Smarthome.
I succesfully have added it to the Mi Home App but I can‘t find the section for read out the developer key. Does anyone solved this already or isn‘t it working with v3 of the hub?
All tutorials seems to read out the developer key on an older version of the mi app. In the version if I go to the section of the Hub the „about“ section is not there.
First of all: yes, I did a lot of research but just found threads with similar or the same question but with no solution answer and this is the reason why I asked again in this forum!
I know that this is a help base from other users and I really appreciate this.
I also checked the mentioned thread before, but the user in this thread is using other equipment!
So right now I think that there is no solution. Nevertheless thank you for your support!
Chinese New Year is in 2 weeks from now. Ver.1.5.0_000 and LAN protocol is still not included - it means that if no implementation next week - next chance is after 4-5 weeks, not any earlier
