Hi All,
i would need your help regarding the aqara motion sensor with zigbee2mqtt.
Occupancy is flapping between ON and OFF without any motion detection.
The only thing i found in the www is the issue with “no occupancy false” + weak signal.
Thank you for your support.
Here is my thing configuration
Thing topic MotionSensor "MotionSensor" {
Channels:
Type switch : occupancy "occupancy" [
stateTopic = "zigbee2mqtt/MotionSensor",
transformationPattern="JSONPATH:$.occupancy",
on="true", off="false"]
Type number : illuminance "illuminance" [
transformationPattern="JSONPATH:$.illuminance"]
Type number : Motion_linkquality "linkquality" [
stateTopic= "zigbee2mqtt/MotionSensor",
transformationPattern="JSONPATH:$.linkquality"
Item configuration:
/MotionSensor
Switch occupancy "MotionSensor [MAP(MotionSensor.map):%s]" <motion> {channel="mqtt:topic:mybroker:MotionSensor:occupancy" }
Number illuminance "illuminance [%d lumen]" {channel="mqtt:topic:mybroker:MotionSensor:illuminance"}
Number Motion_linkquality "linkquality [%d]" {channel="mqtt:topic:mybroker:MotionSensor:Motion_linkquality"}`
OH Log
020-11-18 20:48:36.270 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:49:18.058 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:49:35.826 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:49:49.912 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:49:51.612 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:51:06.005 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:51:09.117 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:51:29.421 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:51:29.520 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:52:18.639 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:52:21.187 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON
2020-11-18 20:52:49.264 [vent.ItemStateChangedEvent] - occupancy changed from ON to OFF
2020-11-18 20:52:50.670 [vent.ItemStateChangedEvent] - occupancy changed from OFF to ON``
