OpenHab 2.5_M4 with deCONZ binding using aqara sensors (window/door and temperature/humidity).
Sensors are available in the Phoscon App.
When I restart the openhab service, it can happen that some of the sensors don’t initialize. Then, they don’t work (waiting over night they don’t show up). I have to restart several times until all are “online”.
Log entry:
2019-11-17 15:06:16.254 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Bad’ changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed to OFFLINE (COMMUNICATION_ERROR): Auth failed
2019-11-17 15:06:16.264 [hingStatusInfoChangedEvent] - ‘deconz:humiditysensor:homeserver:tFeuchte_Bad’ changed from OFFLINE (CONFIGURATION_PENDING) to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed
When it works, I get it continued. Log from the reboot:
2019-11-17 15:19:33.677 [temChannelLinkRemovedEvent] - Link ‘batTemperatur_Arbeitszimmer => deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer:battery_level’ has been removed.
2019-11-17 15:19:33.810 [temChannelLinkRemovedEvent] - Link ‘Temperatur_Arbeitszimmer => deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer:temperature’ has been removed.
2019-11-17 15:19:33.889 [temChannelLinkRemovedEvent] - Link ‘update_Temperatur_Arbeitszimmer => deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer:last_updated’ has been removed.
2019-11-17 15:21:18.895 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2019-11-17 15:21:22.358 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2019-11-17 15:21:22.461 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING)
2019-11-17 15:21:24.766 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from OFFLINE (CONFIGURATION_PENDING) to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed
2019-11-17 15:21:24.912 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 2000 ms elapsed to OFFLINE (COMMUNICATION_ERROR): Auth failed
2019-11-17 15:21:29.709 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from OFFLINE (COMMUNICATION_ERROR): Auth failed to OFFLINE (CONFIGURATION_PENDING)
2019-11-17 15:21:29.820 [me.event.ThingUpdatedEvent] - Thing ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ has been updated.
2019-11-17 15:21:30.693 [me.event.ThingUpdatedEvent] - Thing ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ has been updated.
2019-11-17 15:21:30.717 [me.event.ThingUpdatedEvent] - Thing ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ has been updated.
2019-11-17 15:21:30.781 [hingStatusInfoChangedEvent] - ‘deconz:temperaturesensor:homeserver:tTemperatur_Arbeitszimmer’ changed from OFFLINE (CONFIGURATION_PENDING) to ONLINE
2019-11-17 15:21:31.658 [vent.ItemStateChangedEvent] - batTemperatur_Arbeitszimmer changed from NULL to 85
