I’m having trouble with what should be simple. The hardest part is that the log file usually gives me unhelpful error messages like “Error during the execution of rule ‘FloorLampByNight’: Index: 1, Size: 1” which is less than I’d expect from a programming environment.
Anyway I’m trying to incorporate the sunset time (no problem), the cloud cover (problem) and a random wait (problem) into my script to turn on a floor lamp. This is early days for openhab for me and I don’t feel that I have found a suitable reference document from which I can learn how to do things like. The examples I’ve been reading are either too simple, very complex or do things I don’t understand.
var Timer duskTimer
var Number c
var Number randomDelay
var Number cloudDelay
rule "FloorLampOff"
Time cron "0 0 20 * * ?"
sendCommand(FloorLamp, OFF)
FloorLampByNight
If overcast, turn on the light immediately
If clear, wait 25 minutes
Interpolate between those two points for partially cloudy
Add random delay of 0 to 14 minutes
rule "FloorLampByNight"
Item Sunset_event received update ON or
Item test_event received command ON
c = Clouds.state
randomDelay = (new java.util.Random).nextInt(15)
cloudDelay = ((100 - c) / 4).intValue
duskTimer = createTimer(now.plusMinutes(randomDelay) [|
sendCommand(FloorLamp, ON)
I confess I don’t know if I’m getting cloud cover from the weather binding as a percentage or a fraction. I’ve tried both without success, although was at least able to get the code to execute without error with it as a fraction, there was no delay at all even when it was only scattered clouds.
I also haven’t yet understood how to put the equivalent of print statements in the code for debugging. That would be helpful but everything I’ve found so far seems to want me to put XML statements into various files, which is fine if necessary, but I’ve not found an procedure I’m confident to follow at this point.
OK By going through a few more random posts on this forum I found the logInfo function (I guess the XML was for something more sophisticated than writing in openhab.log). So my 3 values are calculated correctly AFAIK.
I changed the value in the call to the plusMinutes method to 1, so it’s something simple I’m missing. The weird thing is that I had something similar working before.
Thanks for the reply Udo. You’re absolutely right, but that’s not the problem. I had exactly what you had there but simplified it to just randomDelay because I was unsure of the value of cloudDelay (whether 0 to 1 or 0 to 100 - I now know it is 0 to 100).
No matter what value I send to plusMinutes, or even if I just put an integer like 1 there, it fails and logs an error.
What kind of item is “Clouds”? I think you need to convert its state to proper type before computation or extract the number from the state, depending on what item type it is.
In the extract from the Log, Clouds is the variable c, a number, which is an value representing the percentage cloud cover.
Here’s the changes I made to test…
c = Clouds.state
logInfo("FloorLampByNight", "Clouds = " + c.toString)
logInfo("FloorLampByNight", "randomDelay = " + randomDelay.toString)
logInfo("FloorLampByNight", "cloudDelay = " + cloudDelay.toString)
duskTimer = createTimer(now.plusSeconds(30) [|
You can see that in createTimer I changed it to seconds and used an integer (i.e. I didn’t use any of the calculations) - but it still fails. So now I just tried commenting out all 6 lines before the one that starts with duskTimer and it still fails, putting the following message into openhab.log.
2015-12-19 09:05:17.500 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘FloorLampByNight’: Index: 1, Size: 1
I must confess that I don’t understand the meaning of the [| … ] syntax, but that’s what all the examples seem to have.
So what I know is that everything up to that line works fine. As a final experiment I commented out the 3 line statement beginning with duskTimer and now it prints out the values of the 3 variables and does not log any errors. Today clouds are 23% (although it is actually overcast and snowing, but that’s not openhab’s fault) and cloudDelay is 19 as I would expect.
I wasn’t importing the org.joda.time.* but it makes no difference. I cut all the fluff I could from the file and I still get the same error. Here’s the rule as it currently stands.It is my only rule file.
rule "FloorLampOff"
No joy. I get the following error if I omit intValue even if I declare randomDelay and cloudDelay as integers.
2015-12-22 16:41:00.112 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘FloorLampByNight’: Could not invoke method: org.joda.time.DateTime.plusMinutes(int) on instance: 2015-12-22T16:41:00.099-05:00
