in the coming Release 3.4.x a new cool rule trigger was introduced:
rule "rule-test-switch-on"
Time is DateTimeItem timeOnly
With this feature I want to develop a switch control widget with time functions (can than easily be adapted to other widget as well, e.g. rollershutter). This is more flexible than a hard coded cron job.
So the Idea is to specify on and off times within the widget.
After finishing I will make it available to the ui widget marketplace.
I hope that there is some interest.
To get it there I need your help
The issues I have are written in Bold font
The Status right now is:
Here the widget is not aligned with the default oh-cell widgets. If possible I want to make it looking the same as the default cell widgets.
pressing the 3 dots:
In the Time Control field I only want to display the adjusted time not the whole DateTime string
When setting the Time the TimeControl Widget is called:
It pops up in the top left corner. It would be better to have it central and maybe a more modern look and feel (ideas welcome).
In the attachment you will find:
Items necessary:
test.items.txt
Test Rules:
test.rules.txt
Yaml of time picker widget:
my_timepicker.txt
Yaml of actual widget:
plug_control.txt
plug_control.txt (9.7 KB)
my_timepicker.txt (9.3 KB)
test.rules.txt (833 Bytes)
test.items.txt (108 Bytes)
