No, you shouldn’t. Instead, you should see a topic update
This line
exten => _X.,1,AGI(/etc/asterisk/agi/agi-mqtt/mqtt,/etc/asterisk/agi/agi-mqtt/mqtt.cfg,calls/doorbirdcall)
will send the calling extension to the topic calls/doorbirdcall
, so when using for example mqtt-spy
and subscribing to the topic calls/doorbirdcall
, you will receive a message {"extension":"<extension>"}
where <extension>
is the number.
To test this from command line, issue this command:
/etc/asterisk/agi/agi-mqtt/mqtt /etc/asterisk/agi/agi-mqtt/mqtt.cfg calls/doorbirdcall 1234567
and press <enter> a second time to end the command. This will publish {"extension":"1234567"}
to calls/doorbirdcalls
