Seems i missed something. Added the thing sun and moon with proper setting of coordinates.
Everything works. But i get the time in paper UI in 12h format. Is there a setting?
I suspect that the time format is derived from the locale of the underlying OS (linux: locale , LC_TIME)
Somehow after service restart all is working nicely.
The only question left is how to get rid of the date so only time remains
If you’re using Basic-UI or Classic-UI, just use a Label with formatting (square brackets) in your items definition or your sitemap, like
astro.items:
DateTime Sunrise_Time "Sonnenaufgang [%1$tH:%1$tM]" { channel="astro:sun:local:rise#start" }
DateTime Sunset_Time "Sonnenuntergang [%1$tH:%1$tM]" { channel="astro:sun:local:set#start" }
That’s exactly what id did.
Items file:
DateTime astro_sunrise_time "Sunrise [%1$tH:%1$tM]" (g_Astro) {channel="astro:sun:local:rise#start"}
DateTime astro_civrise_time "Civil Sunrise [%1$tH:%1$tM]" (g_Astro) {channel="astro:sun:local:civilDawn#start"}
DateTime astro_civset_time "Civil Sunset [%1$tH:%1$tM]" (g_Astro) {channel="astro:sun:local:civilDusk#end"}
Number astro_sun_azimuth "Azimuth [%.2f]" (g_Astro) {channel="astro:sun:local:position#azimuth"}
Number astro_sun_elevation "Elevation [%.2f]" (g_Astro) {channel="astro:sun:local:position#elevation"}
Number astro_moon_illumination "Moon Illumination [%.1f %%]" (g_Astro) {channel="astro:moon:local:phase#illumination"}
DateTime astro_sun_local_civilDawn_start "Civil Sunrise [%1$tr]" (g_Astro) {channel="astro:sun:local:civilDawn#start"}
