Hello everyone,
I currently try to achieve that a rule is triggered as sun as the sunset starts with an offset of 30 minutes. I have the following configuration in place:
Things:
astro:sun:home_offset [ geolocation="51.58196536,7.05765748,88", interval=60 ] {
Channels:
Type start : set#start [
offset=-329
Items:
DateTime Sunset_Time_Offset "Sunset [%1$tH:%1$tM]" { channel="astro:sun:home_offset:set#start" } // Sonnenuntergang
Rule:
rules.JSRule({
description: "Sonnenuntergang",
triggers: [triggers.DateTimeTrigger('Sunset_Time_Offset', false)],
execute: (event) => {
console.log("Sonnenuntergang")
tags: []
rules.JSRule({
triggers: [triggers.ChannelEventTrigger('astro:sun:home_offset:set#start')],
console.log("Sonnenuntergang über channel event")
tags: []
The first rule (outdoor_sunset_on) is triggered, the second one (outdoor_sunset_on_channel_things ) not. If possible I would like to avoid to create an item for this purpose and directly attach the rule towards a channel event trigger. Any idea what I do wrong here?
Cheers
Dennis
