Just tried to install the astro binding. getting this error in logs every 60 seconds or so
12:28:13.619 [ERROR] [.core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-astro': Error:
/var/lib/openhab2/tmp/dbd728ed-activation-1.1.1.jar (Permission denied)
cd /var/lib/openhab2/tmp
ls -l
reveals
-rw------- 1 openhab openhab 32461 Nov 30 01:10 c64c7424-dagger-2.20.jar
-rw------- 1 openhab openhab 70527 Dec 15 17:44 dbd728ed-activation-1.1.1.jar
does the jar need to be executable?
OpenHAB 2.5.0.M5 on a desktop pc I3 8 Gb Ram 1 Tb spiny H/D
H102
(CM6.5 H102)
2
Did you install the binding from PaperUI? If so then restart OH a few times and see if that helps.
sudo systemctl restart openhab2
If you installed the openhabian image then you can also use the openhabian-config tool and run fix permissions option.
ok thanks, so far one restart has not cured the error
the astro binding was installed from Paper UI but I have openhabian-config tool installed.
H102
(CM6.5 H102)
4
Open the tool and select number 10 Apply Improvements then select numbers 11, 13, and 14. This plus two restarts of OH should help.
bingo
12:52:25.687 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'binding-astro' has been installed.
14 fix permissions did it
this community is just amazing
H102
(CM6.5 H102)
6
Glad you got it fixed. and yes everyone here does very well helping each other.
