[SOLVED] Astro binding OH2 keeps repeating events
Hi guys,
19 june i performed a update&&dist-upgrade to the latest and greatest.
I use the snapshots repository.
Since then the astro-binding is repeating its events.
Below i pasted a snippet of my events.log
2017-06-20 21:54:37.059 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:37.064 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:37.073 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:37.075 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:38.078 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:38.086 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:38.094 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:38.099 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:39.036 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:39.040 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:39.040 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:39.052 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:40.034 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:40.039 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:40.045 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:40.058 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:41.065 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:41.067 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:41.071 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:41.081 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:42.058 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:42.065 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:42.079 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:42.085 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:43.052 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:43.070 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:43.072 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:43.085 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:44.093 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:44.098 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:44.098 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:44.103 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:45.047 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:45.052 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:45.061 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:45.066 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:46.055 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:46.063 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:46.068 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
2017-06-20 21:54:46.075 [ItemCommandEvent          ] - Item 'dimmer_hueStaandeLampWoonkamer' received command 77
2017-06-20 21:54:47.058 [ChannelTriggeredEvent     ] - astro:sun:minus90:set#event triggered START
2017-06-20 21:54:47.063 [ChannelTriggeredEvent     ] - astro:sun:local:set#event triggered START
2017-06-20 21:54:47.072 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
Does anybody know what can be done about it?
Thanks upfront,
br,
Raymond
Known issue:
thank you for the info, sorry that i missed that :slight_smile:
br
Raymond
