I recently starting to get this kind of error in the Astro binding
2017-08-17 00:00:00.734 [ERROR] [thome.binding.astro.internal.job.Job] - Queue full
java.lang.IllegalStateException: Queue full
at java.util.AbstractQueue.add(AbstractQueue.java:98)[:1.8.0_101]
at org.eclipse.smarthome.binding.astro.handler.AstroThingHandler.addJobToQueue(AstroThingHandler.java:314)[188:org.eclipse.smarthome.binding.astro:0.9.0.b5]
at org.eclipse.smarthome.binding.astro.internal.job.Job.schedule(Job.java:58)[188:org.eclipse.smarthome.binding.astro:0.9.0.b5]
at org.eclipse.smarthome.binding.astro.internal.job.Job.scheduleSunPhase(Job.java:156)[188:org.eclipse.smarthome.binding.astro:0.9.0.b5]
at org.eclipse.smarthome.binding.astro.internal.job.DailyJobSun.run(DailyJobSun.java:89)[188:org.eclipse.smarthome.binding.astro:0.9.0.b5]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
It usually happens after the binding is running for some days/weeks.
- Anyone else having this issue?
- Is it something internal to the Astro binding or some system limitation?
Thanks for your help in advance
OvO
I am using OH2.1
