Hi all
Using this rule now for many weeks without any issue:
rule "Sunset"
Channel ‘astro:sun:local:set#event’ triggered START
if(HarmonyActivity.state == “PowerOff”) {
sendCommand(Light_Sofa_Dimmer, “90,50,50”)
sendCommand(Light_Kino_Dimmer, “90,50,50”)
} else {
sendCommand(Light_Sideboard_Toggle, ON)
sendCommand(Light_GarageWest_Toggle, ON)
sendCommand(Light_GarageOst_Toggle, ON)
sendCommand(Light_Terrasse_Toggle, ON)
Now with latest openHAB2-Snapshots this trigger is starting again and again:
2017-06-20 21:29:55.049 [ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
2017-06-20 21:29:55.066 [ItemCommandEvent ] - Item ‘Light_Sofa_Dimmer’ received command 90,50,50
2017-06-20 21:29:55.081 [ItemCommandEvent ] - Item ‘Light_Kino_Dimmer’ received command 90,50,50
2017-06-20 21:29:55.096 [ItemCommandEvent ] - Item ‘Light_GarageWest_Toggle’ received command ON
2017-06-20 21:29:55.113 [ItemCommandEvent ] - Item ‘Light_GarageOst_Toggle’ received command ON
2017-06-20 21:29:55.136 [ItemCommandEvent ] - Item ‘Light_Terrasse_Toggle’ received command ON
2017-06-20 21:29:56.040 [ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
2017-06-20 21:29:56.056 [ItemCommandEvent ] - Item ‘Light_Sofa_Dimmer’ received command 90,50,50
2017-06-20 21:29:56.070 [ItemCommandEvent ] - Item ‘Light_Kino_Dimmer’ received command 90,50,50
2017-06-20 21:29:56.085 [ItemCommandEvent ] - Item ‘Light_GarageWest_Toggle’ received command ON
2017-06-20 21:29:56.103 [ItemCommandEvent ] - Item ‘Light_GarageOst_Toggle’ received command ON
2017-06-20 21:29:56.121 [ItemCommandEvent ] - Item ‘Light_Terrasse_Toggle’ received command ON
2017-06-20 21:29:57.058 [ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
2017-06-20 21:29:57.075 [ItemCommandEvent ] - Item ‘Light_Sofa_Dimmer’ received command 90,50,50
2017-06-20 21:29:57.094 [ItemCommandEvent ] - Item ‘Light_Kino_Dimmer’ received command 90,50,50
2017-06-20 21:29:57.116 [ItemCommandEvent ] - Item ‘Light_GarageWest_Toggle’ received command ON
2017-06-20 21:29:57.131 [ItemCommandEvent ] - Item ‘Light_GarageOst_Toggle’ received command ON
2017-06-20 21:29:57.147 [ItemCommandEvent ] - Item ‘Light_Terrasse_Toggle’ received command ON
2017-06-20 21:29:58.052 [ChannelTriggeredEvent ] - astro:sun:local:set#event triggered START
2017-06-20 21:29:58.069 [ItemCommandEvent ] - Item ‘Light_Sofa_Dimmer’ received command 90,50,50
2017-06-20 21:29:58.083 [ItemCommandEvent ] - Item ‘Light_Kino_Dimmer’ received command 90,50,50
2017-06-20 21:29:58.095 [ItemCommandEvent ] - Item ‘Light_GarageWest_Toggle’ received command ON
2017-06-20 21:29:58.115 [ItemCommandEvent ] - Item ‘Light_GarageOst_Toggle’ received command ON
2017-06-20 21:29:58.137 [ItemCommandEvent ] - Item ‘Light_Terrasse_Toggle’ received command ON
Every second or something like that. For sure I’m not able to switch off my lights anymore
Did I miss a new setting or should I open a case for that?
Michael
