I’m facing the same issue, none of my DSL rules trigger on the triggers from the astro events. I’m on OH5.1 release version using the Docker image. Was there any related improvement in 5.1.1? Any feedback from the debug ongoing?
Thanks!
Thanks!
The problem has been fixed as far as our testing has shown, but unfortunately, the fix wasn’t included in 5.1.1. It’s in the latest snapshots, and will be in 5.1.2. It is possible to replace the bundle with the one I have posted above for 5.1.0 - it should fix it, but I’m not sure if that bundle will work correctly with 5.1.1. The bundle in the latest snapshot releases should work with 5.1.1, but I’m not sure what the download address is for that. It’s available via Maven, but OH is using some “non-standard” Maven repository, so the artifacts don’t seem to be available at Maven Central. Somebody else here probably knows where to find them.
edit: I think you can download the latest bundle from here (to use with 5.1.1):
However, I would wait until tomorrow (assuming that the coming night’s build is successful), because I did a small fix to how this fix integrated with some other changes today. The builds run during the night, so what was done today isn’t yet in the snapshot.
Generally, the snapshot builds are updated as development continues, so while the current snapshots (despite being called 5.2.0-SNAPSHOT) should work fine with 5.1.1, that may no be true in a couple of months. As such, of somebody finds a snapshot bunde that fixes the issue and works fine with 5.1.1, somebody should probably post a link to that exact version for use with 5.1.1.
To future visitors, this should be fixed in 5.1.2.
… yes, it does ![]()
