polve93
(Manuel)
1
Hi all, my rule does not trigger at the right time (it activates with 2 hours delay).
Clock and timezone are correct in:
- PaperUi settings
- Openhab log
- Raspberry pi4 system clock (where OH is running)
Astro sunset time is correct. Rule is:
rule "Sunset"
Channel "astro:sun:home:set#start" triggered START
power.sendCommand(ON)
What is wrong with this configuration?
ubeaut
(Greg)
2
It should be:
Channel ‘astro:sun:home:set#event’ triggered START
not
Channel “astro:sun:home:set#start” triggered START
rossko57
(Rossko57)
3
Sounds like you should check your base operating system timezone setting
polve93
(Manuel)
4
I will try
@rossko57 Base operating system timezone setting is already correct
rossko57
(Rossko57)
5
What’s in your events.log
? You should be able to find both the astro event and your rule-issued command
polve93
(Manuel)
6
Problem solved, thank you anyway.
