I have just upgraded from Openhab v3.2.0 to v. 3.3.0. on my RPI3B+. After the upgrade the astro thing “Astro Sun Data” doe not work with the following message:
2022-07-08 18:41:45.289 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:47ba2aac' changed from UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): {earliest=The value does not match the pattern ^([0-1][0-9]|2[0-3])(:[0-5][0-9])$.} to UNINITIALIZED
2022-07-08 18:41:45.303 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:47ba2aac' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2022-07-08 18:41:47.379 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'astro:sun:47ba2aac' changed from UNINITIALIZED (DISABLED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING): {earliest=The value does not match the pattern ^([0-1][0-9]|2[0-3])(:[0-5][0-9])$.}
In fact is not an INFO but an ERROR. “Earliest” is defined at channel level but the whole thing if OFF. And I have not found anything “special” in channels
Does anyone know how to fix it? (I would not like to create a new thing and start again linking with items)
