Astro Items+Sitemap+Map+♈ Binding Example
where is the english version of astro.map file with emoticons ?
@ers here you go, English version with icons
ARIES=♈ Aries
TAURUS=♉ Taurus
GEMINI=♊ Gemini
CANCER=♋ Cancer
LEO=♌ Leo
VIRGO=♍ Virgo
LIBRA=♎ Libra
SCORPIO=♏ Scorpio
SAGITTARIUS=♐ Sagittarius
CAPRICORN=♑ Capricorn
AQUARIUS=♒ Aquarius
PISCES=♓ Pisces
SPRING=Spring
SUMMER=Summer
AUTUMN=Autumn
WINTER=Winter
SUN_RISE=Sunrise
ASTRO_DAWN=Astronomical Dawn
NAUTIC_DAWN=Nautical Dawn
CIVIL_DAWN=Civil Dawn
CIVIL_DUSK=Civil Dusk
NAUTIC_DUSK=Nautical Dusk
ASTRO_DUSK=Astronomical Dusk
SUN_SET=Sunset
DAYLIGHT=Day Time
NOON=Noon
NIGHT=Night Time
NEW=🌑 New Moon
WAXING_CRESCENT=🌑→🌓 Waxing Crescent
FIRST_QUARTER=🌓 First Quarter
WAXING_GIBBOUS=🌓→🌕 Waxing Gibbous
FULL=🌕 Full Moon
WANING_GIBBOUS=🌕→🌗 Waning Gibbous
THIRD_QUARTER=🌗 Third Quarter
WANING_CRESCENT=🌗→🌑 Waning Crescent
Also translation to Slovenian
ARIES=♈ Oven
TAURUS=♉ Bik
GEMINI=♊ Dvojčka
CANCER=♋ Rak
LEO=♌ Lev
VIRGO=♍ Devica
LIBRA=♎ Tehtnica
SCORPIO=♏ Škorpijon
SAGITTARIUS=♐ Strelec
CAPRICORN=♑ Kozorog
AQUARIUS=♒ Vodnar
PISCES=♓ Riba
SPRING=Pomlad
SUMMER=Poletje
AUTUMN=Jesen
WINTER=Zima
SUN_RISE=Sončni Vzhod
ASTRO_DAWN=Astronomska Zora
NAUTIC_DAWN=Navtična Zora
CIVIL_DAWN=Civilna Zora
CIVIL_DUSK=Civilni Mrak
NAUTIC_DUSK=Navtični Mrak
ASTRO_DUSK=Astronomski Mrak
SUN_SET=Sončni Zahod
DAYLIGHT=Dan
NOON=Opoldan
NIGHT=Noč
NEW=🌑 Mlaj
WAXING_CRESCENT=🌑→🌓 Prehod iz Mlaja
FIRST_QUARTER=🌓 Prvi Krajec
WAXING_GIBBOUS=🌓→🌕 Prehod v Ščip
FULL=🌕 Ščip
WANING_GIBBOUS=🌕→🌗 Prehod iz Ščipa
THIRD_QUARTER=🌗 Drugi Krajec
WANING_CRESCENT=🌗→🌑 Prehod v Mlaj
i have the same, but on the android app, i see the icons
dont forget to cope one image and call it moonphase.svg, without this, it will not work
i had this problem, after this, it works with multible pictures
@ThomDietrich:
Thank you for your great work and the detailed description to use the astro binding!!!
I use your example to schow the astro datas on my dashboard. It works.
I noted that I have for example in the sunrise and sunset a difference from some minutes (approximately 5-6min) compared for example with this or this site and the datas in a newspaper. The datas from the newspapper and the link are equal.
I assume there are different calculation approaches.
Did I do something wrong?
Did someone notice a difference, too?
Danish Translation:
ARIES=♈ Vædderen
TAURUS=♉ Tyren
GEMINI=♊ Tvillingerne
CANCER=♋ Krebsen
LEO=♌ Løven
VIRGO=♍ Jomfruen
LIBRA=♎ Vægten
SCORPIO=♏ Skorpionen
SAGITTARIUS=♐ Skytten
CAPRICORN=♑ Stenbukken
AQUARIUS=♒ Vandmanden
PISCES=♓ Fisken
SPRING=Forår
SUMMER=Sommer
AUTUMN=Efterår
WINTER=Vinter
SUN_RISE=Solopgang
ASTRO_DAWN=Astronomisk daggry
NAUTIC_DAWN=Nautisk daggry
CIVIL_DAWN=Civil daggry
CIVIL_DUSK=Civil skumring
NAUTIC_DUSK=Nautisk skumring
ASTRO_DUSK=Astronomisk skumring
SUN_SET=Solnedgang
DAYLIGHT=Dagslys
NOON=Middagstid
NIGHT=Nat
NEW=🌑 Nymåne
WAXING_CRESCENT=🌑→🌓 Tiltagende halvmåne
FIRST_QUARTER=🌓 Første kvarter
WAXING_GIBBOUS=🌓→🌕 Tiltagende fuldmåne
FULL=🌕 Fuldmåne
WANING_GIBBOUS=🌕→🌗 Aftagende fuldmåne
THIRD_QUARTER=🌗 Tredje kvarter
WANING_CRESCENT=🌗→🌑 Aftagende halvmåne
NULL=ukendt :exclamation_question_mark:
-=ukendt :exclamation_question_mark:
Hi. My OpenHAB 2.4.0.1 running on a Raspberry Pi 3 still has problems showing the unicode symbols.
The Astrobinding is installed and configured right (at least I think so): I just set up sunrise, sunset, zodiac signs, full moon and new moon. My sitemap displays all data correctly, just the unicode symbols are exchanged with ??? - using Firefox as well as the OpenHAB Android app from FDroid. I verified that the astro.map file is encoded in UTF8, created a new astro.map with another texteditor in the UTF8 format and downloaded the astro.map provided by @ThomDietrich . None of my approach could solve the problem. Does anyone have an idea what else I could try?
can you send me the svg
Hi Fawad,
I have added the file extension “.txt” as it is not allowed to upload “.zip” files.
Just remove the “.txt” and the you can simply unzip the file. Put it into the directory tree as described. Have fun!
Moonphases-SVG.zip.txt (666.2 KB)
Thanks Justus, i was able to download the zip. Thanks again for the files mate
You are welcome. I am happy that I can share something with the community :wink:
How do you insert Text item=Current_Date Time into your sitemap title bar?
If you are still making these svgs available I would appreciate getting them.
Thanks!
Hello Justus,
I like this moon icons. Can you send me the svg files pleas.
Greetings David
hi all! thx for the nice icons! are you still able to use those in oh3? i’m struggling to get them to work. Not for the item itself nor a widget :confused:
Here’s how I configure dynamic icons in openHAB3:
  • For your Item representing the mon phase, edit the metadata and choose “default list item widget”. * Tick “Show advanced” at the top right
  • Now set the Icon depends on state control to ON (default value is OFF)
  • Specify the name of the dynamic icon (*)
(*) If you stored your icons the usual way (i.e., under ${OPENHAB_CONF}/icons/classic/ (on my Raspberry Pi: /etc/openhab/conf/icons/classic/), then you should prefix your icon with oh: to make them visible in mainUI. Remember to name your icons according to the following template:
<icon name>-<state>.<extension>
Note that dynamic icons are never shown when browsing / editing the `Items through the Settings menu. They only appear on pages etc. where (list) widgets are rendered.
I would probably use moon age (provided by the astro binding as e.g. the astro:moon:home:phase#agePercent channel) to render the moon phase with dynamic icons. The icons would then be named moon_age-0.svg, … moon_age-100.svg and also a default moon_age.svg icon. Given the SVG file it should be relatively easy to create intermediate moon_age-<age>.svg files by properly configuring the dark overlay.
I had the same struggle myself and solved it to copy one icon to a icon called moonphases.png.
(works in basic UI converted from svg to png because ? they do not mix)
The tip was already given some where in the topic
Thanks for the moon icons, very great!. Remember that to use it, we need a “not qualified” icon also. I have cloned “moonphases-full.svg” and renamed as “moonphases.svg”.
Ruben
