sure
Frame label=“Weather” {
Text item=Condition_Id icon=“yahoo_weather” {
Frame {
Text item=Weather_LastUpdate visibility=[Weather_LastUpdate>30] valuecolor=[Weather_LastUpdate>120=“orange”, Weather_LastUpdate>300=“red”]
Text item=Sunrise_Time
Text item=Sunset_Time
Everything looks right in your cfg, items and sitemap settings. I’m wondering if time calculation uses your system clock, and your system clock is off by 12 hours? Probably a bad guess, but I can’t explain it any other way. Hopefully someone with more knowledge of OH and Astro binding will chime in.
Double check your lat and long,
latitude in India should be between 8 and 31, longitude between 70 and 85
You can find out the values easily here: http://www.latlong.net/
