Check via karaf and bundle:list which exact version of the astro binding you have active.
Since versioin 0.9.0.201705231820 the error should have gone …
Didn’t help and uninstall via paper ui and reinstall doesn’t help either is trehre some special way for windows users or is it snapshot repository not up to date with astro binding.
It was tricky go get the add-ons to update, when config was restored from
old setup. I dropped the add-on packet file from the snapshot build site
into the add-ons folder, and that seem to have done the trick.
It seems like I’m no getting there downloaded an new .kar file put that one into /addons unistalled astrobinding and installed it but no success. Maybe I’m doing sometrhing wrong, didn’t download those in git hub where it sais astro binding didn’t run I huess that only means that no compilation was done
I have absolutely no idea. With all the recent changes to the location of the builds I lost track …
I doubt that any .kar file will include the astro binding.
And I was not able to find yet the location of precompiled jars at Eclipse … sorry.
Finally I’ve made it but in a real uggly way, set up a stand alone installation fpr #927 and installed astro binding then I’ve had 0526 version of binding, deleted astrobinding that where hosted from openhab in my normal installation. Then copied 0526 version into C:\openhab-2.1.0-SNAPSHOT\userdata\tmp\mvn\org\eclipse\smarthome\binding unistalled.
The I started the bormal installation uninstalled binding via paper ui and the installed and finally I had 0526 running.
