In Astro there is something like PositionalJob and this is executed as how often as configured in the thing refresh interval. I have chenged it in my openHAB test environment to 15 seconds, so the channel values are updated every 15 seconds.
There is also a DailyJobSun which is executed 30 seconds after the midnight and registers the assynchronous triggers for all of the astro events (so it seems to be possible to set a thing refresh interval to some high value - like every 6 hours - and those asynchronous triggers will publish events at the correct time anyway).
I have made a short tests around passing the midnight from 16th Jun to 17th Jun, for city Warsaw in Poland.
Before midnight I had something like below in the log:
23:59:57.285 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_start updated to 2019-06-16T23:10:00.000+0200
23:59:57.349 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_end updated to UNDEF
23:59:57.355 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_duration updated to UNDEF
23:59:57.460 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_phase_name updated to ASTRO_DUSK
It says UNDEF for astroDusk_end and astroDusk_duration, however the phase_name phase name is calculated correctly to ASTRO_DUSK. In the source code - I see - that to calculate the phase name it silently assumes that ASTRO_DUSK ends at midnight however it says that the end time is UNDEF.
Interesting thing is when the date changes, right after the midnight:
00:00:12.293 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_start updated to 2019-06-17T23:11:00.000+0200
00:00:12.297 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_end updated to UNDEF
00:00:12.302 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDusk_duration updated to UNDEF
00:00:12.247 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_start updated to UNDEF
00:00:12.252 [safeCall-1] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_end updated to 2019-06-17T02:06:00.000+0200
00:00:12.257 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_astroDawn_duration updated to UNDEF
00:00:12.494 [safeCall-3] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_phase_name updated to ASTRO_DAWN
Right after the midnight Astro calculates the DUSK to be at the end of the current date but it wrongly calculates that we are in ASTRO_DAWN since the midnight, and the current sun phase is wrongly calculated to ASTRO_DAWN. The correct result should be:
ASTRO_DUSK till 17 May 00:36
ASTRO_DAWN from 17 May 00:36 till 02:04
NAUTIC_DAWN in my case is calculated correctly.
Another interesting thing. I have changed the date in my computer to 20 Apr 2019, to see how Astro calculates NIGHT. Here it is:
09:44:27.416 [safeCall-3] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_start updated to 2019-04-20T21:59:00.000+0200
09:44:27.422 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_end updated to 2019-04-21T03:10:00.000+0200
09:44:27.429 [safeCall-2] INFO smarthome.event.ItemStateEvent:53 - astro_sun_8c2f8c23_night_duration updated to 311 min
Its startTime is on 20th Apr but endTime is on 21th Apr. The duration is calculated correctly (as a difference of endTime and startTime). So for NIGHT it desn’t truncate to midnight but it shows the real night end on the next day.
Could Astro do the same with ASTRO_DUSK, NAUTIC_DUSK and CIVIL_DUSK?
I have the feeling that Astro was at first designed to provide events related to the specific date but we observe a weired behavior around midnight for a high latitude locations. I also feel that Astro should deliver events related to the current day but there are some special cases when we have two the same events at the same date (like two ASTRO_DUSK or two NAUTIC_DUSK and so on) but Astro is able to deliver only one of them at the time. So maybe it could provide events for the current date but - in case of doubled events - it should provide the closesd one? This means that Astro should also reschedule the event triggering after the NOON?
Also the Sun’s noon is not alwasy at 12:00. In the north latitude on earth the Sun’s noon is around 12:30 on Jun and around 11:30 on Dec. The same relates the Sun’s midnight: it varies from 23:30 to 00:30, so the ASTRO_DUSK may end between 23:30 and 00:30.
This is a good question. At least the current sun phase name should be correctly calculated to DAYLIGHT or NIGHT.
From one side - we take again an example of ASTRO_DUSK - if Astro truncates the ASTRO_DUSK to midnight, then it should generate two ASTRO_DUSKs:
ASTRO_DUSK = 16th Jun 23:10 -> 17th Jun 00:00
ASTRO_DUSK = 17th Jun 00:00 -> 17th Jun 00:36
then astroDusk#start will be generated twice. What if I have a rule in my openHAB, to switch on some lights for 30 minutes on every astroDusk#start? Then I expect the lights to be on only between 23:10 and 23:40, but not on 00:00 and 00:30.
