Here is the thing with channel configuration for Athom EM2 (2 channel).
It assumes that MQTT topic on the device is set to energy_meter
Also, set your bridgeUID to your MQTT bridge.
I haven’t added a summary values (Energy Today, Energy Yesterday, Energy Total) as OpenHab has better ways to display and summarize these values.
Hopefully it will save you an hour to configure all channels.
UID: mqtt:topic:OpenhabianMQTT:EnergyMeter
label: House Energy Meter
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:OpenhabianMQTT
channels:
- id: Channel1Current
channelTypeUID: mqtt:number
label: Current channel 1
description: null
configuration:
postCommand: false
retained: false
unit: A
stateTopic: tele/energy_meter/SENSOR
transformationPattern: JSONPATH:$.ENERGY.Current[0]
- id: Channel2Current
label: Current channel 2
description: null
configuration:
postCommand: false
retained: false
unit: A
transformationPattern: JSONPATH:$.ENERGY.Current[1]
- id: Channel1ActivePower
label: Active power channel 1
description: null
configuration:
postCommand: false
retained: false
unit: W
transformationPattern: JSONPATH:$.ENERGY.Power[0]
- id: Channel2ActivePower
label: Active power channel 2
description: null
configuration:
postCommand: false
retained: false
unit: W
transformationPattern: JSONPATH:$.ENERGY.Power[1]
- id: Voltage
label: Voltage
description: null
configuration:
postCommand: false
retained: false
unit: V
transformationPattern: JSONPATH:$.ENERGY.Voltage
- id: Frequency
label: Frequency
description: null
configuration:
postCommand: false
retained: false
unit: Hz
transformationPattern: JSONPATH:$.ENERGY.Frequency
- id: Channel1ApparentPower
label: Apparent power channel 1
description: null
configuration:
postCommand: false
retained: false
unit: VA
transformationPattern: JSONPATH:$.ENERGY.ApparentPower[0]
- id: Channel2ApparentPower
label: Apparent power channel 2
description: null
configuration:
postCommand: false
retained: false
unit: VA
transformationPattern: JSONPATH:$.ENERGY.ApparentPower[1]
- id: Channel1ReactivePower
label: Reactive power channel 1
description: null
configuration:
postCommand: false
retained: false
unit: VAR
transformationPattern: JSONPATH:$.ENERGY.ReactivePower[0]
- id: Channel2ReactivePower
label: Reactive power channel 2
description: null
configuration:
postCommand: false
retained: false
unit: VAR
transformationPattern: JSONPATH:$.ENERGY.ReactivePower[1]
