I have no trouble exercising these devices individually, but when I use the switch widget in HabPanel, I get this error
2017-02-25 21:24:13.679 [WARN ] [thome.io.rest.core.item.ItemResource] - Received HTTP POST request at ‘items/gAlarmLights’ with an invalid status value ‘ON’.
There is nothing obviously wrong with the config I can see.
But how does the group item look like?
You can experiemement a bit with the REST Api and try to send the same command via POSTMAN or similar and see the result here.
Maybe it’s a bug in the REST API or the HabPanel…, does the other group work fine?
