Hi All,
Wondering if anyone else is using an Emerald Heat pump Hot Water Service? I finally had some time to work on the MQTT side of things, inspired by the HA code at GitHub - ross-w/emerald_hws_py: Python package for controlling Emerald Heat Pump Hot Water Systems · GitHub
Right now, I only support a couple of channels that I’m getting from polling via http, but just today, I’ve started getting mqtt packets from AWS, so tomorrow I should be able to get read-only access to all channels working ok, then I can work on writing commands too.
I’ll be on the lookout for testers ![]()
