I am currently running openHAB2 and recently added an Autelis Controller to my installation. I installed the Autelis binding using the Paper UI Add-ons->Bindings->Autelis Binding. I added the following configuration statement to the mySite.things file:
I believe there is something wrong with this configuration statement as all of my other ‘thing’ cease to work.
THe openhab.log file shows:
2017-03-13 13:44:10.694 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type ‘channel’ of item ‘PoolVersion’ could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: UID must have at least 4 segments.
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:82)
at org.eclipse.smarthome.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:72)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:312)
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.dispatchBindingsPerType(GenericItemProvider.java:268)…
If I remove the configuration statement from the .things file everything works as before and I don’t get the above log entry.
The standard format for a Thing is to have three elements in that first part of the Thing:
Thing <binding id>:<thing type id>:<thing id>
It appears the thing type id is missing. So there appears to be an error in the readme for this binding. Unfortunately, I cannot begin to guess what the correct way to represent it would be. I would try the following:
resolved the issues and the autelis controller initialized properly and went online. I have verified the proper data is being transmitted to openhab (via a sniffer), but there is still an issue in displaying the data. When I resolve that problem I will post the issue.
Yes I have verified that the binding is sending the ‘get status’ command to the autelis box and the box is returning the correct xml data. I can see this with the sniffer and also verified iit by sending the command manually. I believe the problem is in the items statement. The item statement I am using is:
The xml snippet which the autelis returns after the command is:
…0 … 1.0.0……
This means the binding must parse the xml using the ‘-’ as a delimiter. I have tried several different delimiters unsuccessfully. My next step is to check the binding source or email the author.
Yes I examined both the openhab.log and the events.log. The openhab.log showed the autelis controller being initialized and brought online with no errors. Also, the openhab.log showed a parsing error if I replaced the ‘-’ in the item statement with anything but the ‘-’. So oh appears to be parsing the input from the autelis controller, but no data is being displayed. The events.log shows nothing for the autelis interactions at all.
Hi, apologies, I think the docs are not correct. While I use config files to define my items, i let OH2 do autodiscovery to find my pool and configure through the paper ui, which is why this was probably not caught earlier. The correct format should be autelis:poolcontrol:myPool . Also what type of pool system are you connecting to?
I first tried the paper ui to configure the autelis controller, but autodiscovery did not find it. That is why I was doing the manual configuration. I discovered the correct format of autelis:poolcontrol:myPool by trial and error. I think I am getting it initialized properly now, but I am not getting any data displayed using:
Thanks @Larry_Pyle , so is it working for you now? I’m glad we have some other users of this binding, I will update the docs. I’m surprised auto discovery did not work, is your autelis on a different network?
Also to see what channels are available take a look at the thing in the paperui, each channel has a copy icon to copy the channel name to your clipboard.
