Thanks for suggesting chrome debugger, I figured out the chlrp by playing with curl, but I could not figure out pump speed until I looked at network tab in debugger.
I ran into a Autelis bug, when you update the chlrp it updates the Chemistry page in Autelis, but does NOT update Jandy. However, I let them know of the issue and the quickly were able to fix it.
This is b/c we are installing it manually, once it becomes part of the distribution OH/ESH will automatically install dependencies. In the mean time, if you install another binding with that dependency (even if you donāt use it), that should fix it. The Hue binding is probably a good option.
Ok, let me look, I probably mixed up pump and pumps between code, xml and the docs.
Number Pool_Pump_Speed "Pool Pump Speed [MAP(poolPump.map):%s]" <pool_pump> (Pool) {channel="autelis:jandy:Pool:pumps-vsp1"}
If I set the pump speed to 5 through the item Autelis correctly tells Jandy to set the speed to 5. However, if I then set pump speed to 1 in Jandy, the Autelis correctly updates XML to 1:
updating channel autelis:jandy:Pool:pumps-vsp1 with state 1 (old state 5)
Well thats odd, the line says we are calling updateState to that channel ( autelis:jandy:Pool:pumps-vsp1), but since your not seeing the item update, its like the item is not linked to the channel. On the REST swagger page (/doc/index.html#) under ālinks ā GETā if you click on the ātry it outā button, do you see that channel linked to the item?
Two things, one, do you know when this will make it to 2.2.0-SNAPSHOT and two, do you know why this stopped working under 2.2.0-SNAPSHOT a few days ago? Other then upgrading, I made no changes to openHAB.
openhab.log:2017-07-31 10:03:25.180 [INFO ] [org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl] - Loading model 'autelis.things'
openhab.log:2017-07-31 10:03:38.572 [WARN ] [org.apache.felix.fileinstall] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.autelis-2.1.0-SNAPSHOT.jar
openhab.log:org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.autelis [176]
openhab.log:2017-07-31 10:03:45.580 [WARN ] [org.apache.felix.fileinstall] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.autelis-2.1.0-SNAPSHOT.jar
Sorry I have been out the last few weeks. Not sure what happened there, did you install or uninstall another binding? Maybe that process unloaded the autelis binding and could not reinstall it?
Did you ever figure this out? I have not submitted this yet for review, I will plan on doing so over the weekend (or sooner if I can)
Reinstalling did the trick, as far as the pump speed, I still donāt see the item updating when Jandy changes the speed, but I am able to set the speed to whatever I want. Itās not ideal, but for my needs is not a big deal.
I submitted a PR yesterday so hopefully it will be in the nightlies soon. I still want to figure out why that value is not working for you, Iām traveling this week, but when I get a chance I will try and create a debug version to better diagnose the issue.
Hi guys, I installed a Pentair ScreenLogic 2 kit with the IP protocol adapter and a EasyTouch controller. The App is working (but crappy) so I try to setup OH to control. I read the bindig also supports Pentair devices. Does that include the protocol adapter?
