I am just getting around to upgrading to OpenHab2 (starting from scratch), and I am not able to get the Autelis binding working either. The 2.4 binding is installed. Using PaperUI, I can create a Thing of the type “poolcontrol”. But the status shows up as “OFFLINE - COMMUNICATION_ERROR”. When I create a Thing manually in a text file, I can create one of the format autelis:poolcontrol:mypool, but not (as the wiki instructs) of the format autelis:jandy:mypool. The former has the same problem as when created through PaperUI. The connection still works on my OpenHab 1.x install. I’m at a complete loss.
I was able to get it working, but only after finding a random copy of the 2.3 binding on the web (through one of Dan’s postings on this forum) and manually installing that. For some reason the 2.3 binding uses the jandy and pentair Things, but the 2.4 binding uses poolcontrol and does not work at least with my setup.
Edit: I seem to have spoken too soon. The 2.3 binding is definitely better. Now I can at least read the state of each channel, but I still cannot control, for example, the pump.
You did not mention what pool type you have? If its a Jandy/Zodiac and you have their iAquaLink internet controller, i have a binding that talks to that as well in review.
