I’m trying my best to migrate over to OH2. My first attempt has been to get my pool control working in OH2. I have added the Autelis binding, and added the details it requires in the configuration portion - but the device always stays offline or offline-communication error. I am using the same settings (ip address, un, pw, etc) in OH1 and everything connects fine…
Any guidance on what I may be doing wrong? Do I manually have to create a thing? When I added the binding and filled out the configuration information a pool control thing is now present.
The lack of documentation for OH2 is really frustrating…
Sorry! I am traveling to a conference this week and not very responsive. In the paper UI if you go to Configuration -> Things -> Autelis Pool Control and click edit, do the config fields there all look ok? Also is that the openhab.log file or the event.log file? I would expect INFO DEBUG or WARN messages printed there, can you make sure you are looking at openhab.log vs events?
I just did a fresh install of OH2 B4 to make sure I had a virgin palette to work on. I only added the Autelis binding and wind up with the same results.
Here’s the new log file
2016-11-04 21:12:59.610 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-04 21:12:59.657 [INFO ] [core.karaf.internal.FeatureInstaller] - Installed 'openhab-package-standard'
2016-11-04 21:12:59.751 [INFO ] [core.karaf.internal.FeatureInstaller] - Installed 'openhab-package-standard'
2016-11-04 21:13:44.273 [WARN ] [.service.internal.HttpServiceStopped] - Http service has already been stopped
2016-11-04 21:13:44.273 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2016-11-04 21:13:44.273 [ERROR] [org.apache.felix.scr ] - Error while disposing components of bundle org.eclipse.smarthome.ui.paper/180
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:983)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:659)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.osgi.util.tracker.ServiceTracker.removedService(ServiceTracker.java:459)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:967)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:870)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)[org.osgi.core-6.0.0.jar:]
at org.osgi.util.tracker.ServiceTracker.close(ServiceTracker.java:377)[org.osgi.core-6.0.0.jar:]
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:549)
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:414)
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:53)
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:273)
at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:290)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)[:1.8.0_111]
at java.util.concurrent.FutureTask.run(Unknown Source)[:1.8.0_111]
at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:312)
at org.apache.felix.utils.extender.AbstractExtender.stop(AbstractExtender.java:125)
at org.apache.felix.scr.impl.Activator.stop(Activator.java:179)
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:827)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_111]
at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:820)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:950)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:324)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.doStop(Module.java:626)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.Module.stop(Module.java:488)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1623)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1542)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:248)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:145)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:160)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at java.lang.Thread.run(Unknown Source)[:1.8.0_111]
2016-11-04 21:14:13.675 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-11-04 21:14:13.767 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-11-04 21:14:13.845 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-04 21:14:13.894 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
Sorry, not multitasking very well, what happens when you try and hit “http://poolcontrol/app.html” in your browser or better yet using curl or wget from the box running openhab? Is “poolcontrol” the correct hostname for your controller? BTW I need to go back and implement proper discovery of the Autelis device, at the time I did not realize that Autelis supported UPNP. My first thought is that whatever that host is resolving to on your box is not the actually Autelis device.
My Autelis has never responded to http://poolcontrol. I have a static IP address configured for it and it has it’s own FQDN which is resolved via my own DNS server at the house. I have added both the IP address and the FQDN pool.xxx.xxx to the Configuration Parameters of the binding via Paper UI and it looks like those parameters are ignored.
I just tried on my system, and it definitely respects the host option. I have an updated version of the binding that uses proper UPNP to discover the device, let me test that today and I will post an updated jar for you. Just to be clear, if you enter 10.5.1.30 in that field (no http:// prefifix) you get the same error?
Is it respecting the host option if http://poolcontrol works?? - just a thought
Yes, if I enter either the IP address, 10.5.1.30 or the domain name neither works - I get the communication error…what’s really weird is this works in OH1.
I went ahead and added proper UPNP discovery to the binding, you can wait for it to getinto the nightlies or grab a version here:
Let me know if this helps at all, I’m not sure whats going on with you setup. Actually, can you describe what your oh2 environment looks like and if it differs from your OH1 instance?
yes this is very strange, can you try downloading the jar again from https://github.com/digitaldan/openhab2-addons/releases/tag/autelis-upnp ? Kai fixed that missing dependency issue ( i broke the build!) and I added some additional logging to see what URL’s we are attempting to hit when we get that 404 message.
2016-11-12 09:54:04.549 [WARN ] [org.apache.felix.fileinstall ] - Failed to update artifact C:\OpenHab\addons\org.openhab.binding.autelis-2.0.0-SNAPSHOT.jar
org.osgi.framework.BundleException: A bundle is already installed with the name "org.openhab.binding.autelis" and version "2.0.0.201611121528"
at org.eclipse.osgi.container.ModuleContainer.update(ModuleContainer.java:327)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.storage.Storage.update(Storage.java:713)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.update(EquinoxBundle.java:439)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.update(DirectoryWatcher.java:1128)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.update(DirectoryWatcher.java:900)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:481)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:358)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:310)[8:org.apache.felix.fileinstall:3.5.0]
2016-11-12 09:54:04.627 [DEBUG] [org.openhab.binding.autelis ] - BundleEvent UNRESOLVED - org.openhab.binding.autelis
2016-11-12 09:54:04.642 [DEBUG] [org.openhab.binding.autelis ] - BundleEvent RESOLVED - org.openhab.binding.autelis
2016-11-12 09:54:04.658 [DEBUG] [org.openhab.binding.autelis ] - BundleEvent STARTING - org.openhab.binding.autelis
2016-11-12 09:54:04.705 [DEBUG] [org.openhab.binding.autelis ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.UpnpDiscoveryParticipant}={component.name=org.openhab.binding.autelis.discovery.AutelisDiscoveryService, component.id=0, service.id=122, service.bundleid=193, service.scope=bundle} - org.openhab.binding.autelis
2016-11-12 09:54:04.736 [DEBUG] [org.openhab.binding.autelis ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={component.name=org.openhab.binding.autelis.internal.AutelisHandlerFactory, component.id=1, service.id=123, service.bundleid=193, service.scope=bundle} - org.openhab.binding.autelis
2016-11-12 09:54:04.751 [DEBUG] [org.openhab.binding.autelis ] - BundleEvent STARTED - org.openhab.binding.autelis
2016-11-12 09:54:04.876 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/C:/OpenHab/addons/org.openhab.binding.autelis-2.0.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.autelis [190]
Another singleton bundle selected: osgi.identity; osgi.identity="org.openhab.binding.autelis"; type="osgi.bundle"; version:Version="2.0.0.201611121528"; singleton:="true"
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:393)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1245)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1217)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1207)[8:org.apache.felix.fileinstall:3.5.0]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:504)[8:org.apache.felix.fileinstall:3.5.0]
2016-11-12 09:54:09.088 [DEBUG] [org.openhab.binding.autelis ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandler}={thing.type=autelis:poolcontrol, thing.id=autelis:poolcontrol:a3da2858, service.id=222, service.bundleid=193, service.scope=singleton} - org.openhab.binding.autelis
2016-11-12 09:54:09.104 [DEBUG] [nding.autelis.handler.AutelisHandler] - Autelius binding configured with base url http://10.5.1.30:80 and refresh period of 5
2016-11-12 09:54:09.447 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/chem.xml?timestamp=1478966049416 : 404 Not found
2016-11-12 09:54:09.478 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/pumps.xml?timestamp=1478966049447 : 404 Not found
2016-11-12 09:54:10.227 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2016-11-12 09:54:10.711 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2016-11-12 09:54:11.662 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
2016-11-12 09:54:12.551 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2016-11-12 09:54:12.629 [INFO ] [ulation.internal.HueEmulationServlet] - Started Hue Emulation service at /api
2016-11-12 09:54:12.957 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2016-11-12 09:54:13.066 [ERROR] [org.openhab.binding.autelis ] - FrameworkEvent ERROR - org.openhab.binding.autelis
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
2016-11-12 09:54:14.314 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/chem.xml?timestamp=1478966054283 : 404 Not found
2016-11-12 09:54:14.330 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/pumps.xml?timestamp=1478966054314 : 404 Not found
2016-11-12 09:54:19.291 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/chem.xml?timestamp=1478966059259 : 404 Not found
2016-11-12 09:54:19.322 [DEBUG] [nding.autelis.handler.AutelisHandler] - Method failed for http://10.5.1.30:80/pumps.xml?timestamp=1478966059291 : 404 Not found
