When i updated from the version Openhab 3.0.2 to 3.1.0 the binding is not working.
The configuration parameters are ok (ip, username dslf-config, password) but i get the message:
Thing ‘tr064:fritzbox:Fritzbox7590’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): com.sun.xml.messaging.saaj.SOAPExceptionImpl: Unable to create envelope from given source:
Thing ‘tr064:fritzbox:Fritzbox7590’ changed from OFFLINE (COMMUNICATION_ERROR): HTTP-Response-Code 500 (Internal Server Error), SOAP-Fault: 401 () to UNKNOWN
Any idea how to solve the problem? Thanks in advance.
Hi, same issue here. OH 3.2.0, Fritzbox 7590 with SW v7.29 (= lastest version), tried the Fritzbox-generated username and pwd, and a new one - same error message. Any further ideas? BR Alex
I found the solution: you need to use the name with which the Fritzbox is reachable in the browser instead of the IP address. If you dont know it, got to Fritzbox settings/Home Network/Fritzbox Name and set a name. I used “fritz.box”. Entered the same in OH settings of the TR64 thing and it worked immediately.
