Auto-reconnect openhab app after disconnect
A wall mounted tablet is permanently connected to openhab. If there is a disconnect between openhab and the tablet, due to a restart of openhab or of the wifi router, the tablet does not re-establishmthe connection and the iOS app stays blank.
I am starting to find a solution for this, maybe as a iOS shortcut, tasker or the like. As it is a client side problem, I don’t think it can be solved by rule or server side, can‘t it? Before starting I just like to ask if someone already found an elegant solution for this.
Ideally, a reconnect option should be abailable in the iOS app, what do you think?
