Ok the doc makes me confused when it put Service section inside Manual Installation.
http://docs.openhab.org/installation/linux.html#manual-installation
What about autostart OH2 as a service if I choose package installation?
Just a little positive feedback, the documents for OH2 is quite disorder. If it wants to warn users something (DO NOT part) please put it in the first lines . The Package Installation and Manual Installtion Instruction must be more separated ( for example it should be added a skip âManual Instructionâ button if the users choose the âPackageâ one, I think it can avoid people mixing up 2 method)
Itâs done automatically for you.
Not strictly true, you still have to enable it by following the instructions printed on the screen after the first install, which will depend on your system.
Okay, thx, havenât done a new install since a while âŠ
thanks for your quick reply
This is indeed a bit uncommon. Normally you will see debian packages including a service automatically being activated and started.
@Nguy_n_Phuc_Anh_D_ng but still: All you need to do is follow the instructions. If you followed the package installation instructions you will have seen this part:
Thatâs I believe what you are looking for. Activating and Starting the openHAB background service.
I donât want to silence your concerns but I donât see why you would additionally do anything thatâs under Manual installation if you are clearly not doing a manual installation
