I am try to generate a sitemap. I would like to present a frame. Inside of the frame I want to show all switches from a specific group. Is this possible?
sure this is possible. Put all items in the specific group 1, 2, 3 …:
http://docs.openhab.org/configuration/items.html
itemtype itemname ["labeltext"] [<iconname>] [(group1, group2, ...)] [["tag1", "tag2", ...]] [{bindingconfig}]
and use the group in the sitemap. Or use frames for more flexibility:
http://docs.openhab.org/configuration/sitemaps.html
Thanks for the swift response,
I already put items in Groups
Switch Licht_Waschkueche_Decke_Schalten "Licht WaschkĂĽche Decke schalten" (Waschkueche,Licht,Schalten) { knx="1/1/0+1/5/0" }
Switch Licht_Chillerzimmer_Decke_Schalten "Licht Chillerzimmer Decke schalten" (Chillerzimme,Licht,Schalten) { knx="1/1/12+1/5/12" }
Switch Licht_Flur_2OG_Decke_Schalten "Licht 2.OG Decke schalten" (Flur_2OG,Licht,Schalten) { knx="1/1/25+1/5/25" }
Then, in the sitemap I want to show all items in Group “Licht” in a frame without name all expliciet.
sitemap _default label="Test" {
Frame item=Licht
But in the Frame “Licht” appearing no items. I don’t want to show them in a group on my site.
Is this possible?
Does anybody has an idea? Sure, I can add all items by hand. But I like the programing way
Frame {
Group item=Licht
Then, I getting a group as a collection of all Items “Licht”. I want to have all Items from group “Licht” in a frame. Without any grouping in the UI.
oops … ok
Does your sitemap file contain any other info?
If not, add the closing curly bracket:
Frame item=Licht
I will test it on my system also and let you know… edit: it didn’t work
Yes, I have the curly brackets and just simplified with these only three lines. Unfortunately its not working :-(. But thanks for testing on your System.
something is not right…
I am still trying to get it to work but I can’t seem to make it happen…
I tried several combos… Maybe it’s because I am still at the first cup of coffee…
I will inject some more caffeine into my system, try again and let you know
Nope… I got close, but no cigar…
Tried:
i) Frame item=gGF
ii) Frame item=gGF { Text label="Test" }
It works like:
Frame { Group item=gGF }
It also works with a simple item (not a group):
Frame item=WU_Temp
Conclusion: You can’t use Group Item Types in the Frame element.
I will open up an issue in the docs.openhab.org to make note of this in http://docs.openhab.org/configuration/sitemaps.html#element-type-frame
This is not possible, but there is a PR that tried to implement such a feature. If you are interested in it, you can try to revive it
