@rlkoshak Hi I was hoping you may be able to help me. I have openhab running with my phillips hue bridge. I was able to get all of my phillips hue lights working properly and one sylvania lightify socket/on/off switch with the Phillips Hue Bridge. I grouped all of my lights in Paper UI as “All Lights Switch” however since I had to manually add the socket item via SSH it wont allow me to add it to the “All Lights Switch” group via Paper UI. Can you help advise how to get it to work with the group? Below is the home.items file
It isn’t clear but I think your problem is you are mixing PaperUI and .items files. Since you are defining your Items in a .items file, do everything through the .items file. This means, do not add the Items to your all lights group through PaperUI. Generally, PaperUI is not able to do much of anything with Items bound to 1.x version bindings.
Thank you I was able to solve the issue by creating a “All Lights” Rule in paper UI. Now when i click the all lights button in habpanel the socket switches turn off along with all of the phillips hue bulbs.
I am getting following error when using Time of Day Design Pattern rule,
2018-07-19 05:15:44.924 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'timeofday.rules'
2018-07-19 05:15:46.089 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'timeofday.rules', using it anyway:
The use of wildcard imports is deprecated.
Function3 is a raw type. References to generic type Function3<P1, P2, P3, Result> should be parameterized
The method getCalendar() from the type DateTimeType is deprecated
2018-07-19 05:15:46.093 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'timeofday.rules'
2018-07-19 05:15:51.214 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Error during the execution of startup rule 'Get time period for right now': Could not cast NULL to org.eclipse.smarthome.core.library.types.DateTimeType; line 22, column 37, length 34
