When I autostart openhab nothing happens. I found this in the log:
2016-03-09 00:18:07.925 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyACM0
2016-03-09 00:18:07.926 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
2016-03-09 00:18:07.928 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2016-03-09 00:18:08.027 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2016-03-09 00:18:08.029 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2016-03-09 00:18:08.031 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyACM0
2016-03-09 00:18:08.118 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyACM0 does not exist
2016-03-09 00:18:12.931 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
Based on the speed when doing it manually I’d doubt it is processing to fast to see the stick. Any thoughts?
watou,
Not sure how to tell what user is running the script. I have added a few random users to the dialout group but have not gotten lucky yet.
Toneus,
I have not removed the Z-Stick and I have rebooted several times.
ls -la /dev/ttyA* returns:
crw-rw-rw- 1 root dialout 166, 0 Mar 9 14:10 /dev/ttyACM0
crw–w---- 1 root tty 204, 64 Mar 9 14:04 /dev/ttyAMA0
