I’ve been running a few tests with a switch item that has autoupdate="false"
in the binding configuration. My sitemap switch has a mapping for on & off, so I get two buttons next to each other in the UI.
It appears as if in the Classic UI this works well – the button is pressed, but the UI does not change until the state is updated by the binding. Same thing for the iOS UI – it appears to work well.
The Basic UI seems to not respect autoupdate="false"
and updates the state of the UI immediately, rather than waiting for the state to change.
Is this expected behaviour?
