Hey,
I can easly taken an average of numbers (fe lux, temperature…) with sitemaps.
Group:Number:AVG ALL_hel “Helderheid [%.1f Lux]”
Group:Number:AVG ALL_tem “Temperatuur [%.1f C]”
Is there a way that I can do the same with open/close status of all my windows?
Fe I would like to have to have a global status that’s telling me how many things are open (fe 2).
Group:Number:AVG ALL_con “Open/Dicht”
You simply have to use a contact Group:
Group:Contact:OR(OPEN, CLOSED) ALL_con "Number of open contacts [%d]"
This will count OPEN
contacts. If you wish to count CLOSED
contacts, you would have to change the order in the brackets. This group will state OPEN
, if any Contact in the group is OPEN
Is working great this way.
I’m seeing how many devices are open, and when I click it, a nice list of them all…
items.default:
Group:Contact:OR(OPEN, CLOSED) ALL_con “Deuren/Vensters [%d open]”
Contact Deur_Bureau “Bureau Deur [%s]” (ALL_con,AT_con) { zwave=“8:command=SENSOR_BINARY,sensor_type=10,respond_to_basic=true” }
Contact Deur_Hal “Hal Achterdeur [%s]” (ALL_con,WO_con) { zwave=“5:command=sensor_binary,parameter=10,respond_to_basic=true” }
sitemap.default
Text item=ALL_con {
Frame {
Text item=Deur_Inkom
Text item=Venster_Bibliotheek
Text item=Venster_Keuken
Text item=Venster_L_Leefruimte
Thanks!!!
Even more… I use this snippet:
Group item=GLights icon="switch" {
Switch item=GLights mappings=[OFF="Off"]
Slider item=Light_FF_Parents_Planets visibility=[Light_FF_Parents_Planets!=0] sendFrequency=400 switchSupport
Slider item=Light_FF_Parents_Stars visibility=[Light_FF_Parents_Stars!=0] sendFrequency=400 switchSupport
Switch item=Light_FF_Balkon visibility=[Light_FF_Balkon=="ON"]
The superior item shows the number of Lights switched ON, when clicking this item, it will render only light items, that are not OFF, plus a button to switch them all OFF at once
I see.
But in my case, we’re just talking about door/window sensors.
So not really a possibility to close them through openhab. (Yet
No, but to only show the open ones
would shorten the list…
