i want to read an averaga temperature over 20 minutes to initiate the climate to go on or off.I did a lot of research but unsuccessful.
I have the following item config:
Number Temperature_DG_Studio "Temperatur DG Studio [%.1f °C]" <temperature> (Temperature) {knx=" 12/3/1 "}
Number Temperature_DG_Studio_AV "Temperatur AVG DG Studio [%.1f °C]" <temperature> (TempAV)
and entry into rrd4j.persist
Strategies {
// for rrd charts, we need a cron strategy
everyMinute : "0 5 * * * ?"
everyMinutePV : "0 1 * * * ?"
Items {
Temperature* : strategy = everyMinute, restoreOnStartup
TempAV : strategy = everyMinutePV, everyChange, restoreOnStartup
the rule itself looks like that:
// Calculate the average kW from last 75 minutes
rule "Calc Temperature_DG_StudioAverage"
Item Temperature_DG_Studio received update
var tempdgAV = Temperature_DG_Studio.averageSince(now.minusMinutes(75)) as DecimalType
postUpdate(Temperature_DG_Studio_AV, tempdgAV)
The rule is executed well - within the log files i could see taht - but the issue is that the average calculation is not done. the items per log are always from same value:
2017-06-23 19:15:17 - Temperature_DG_Studio received command 25.18
2017-06-23 19:15:17 - Temperature_DG_Studio_AV state updated to 25.1799999999999
2017-06-23 19:15:21 - Temperature_DG_Studio received command 24.88
2017-06-23 19:15:21 - Temperature_DG_Studio_AV state updated to 24.8799999999999
2017-06-23 19:15:26 - Temperature_DG_Studio received command 25.32
2017-06-23 19:15:26 - Temperature_DG_Studio_AV state updated to 25.3200000000000
Any idea? the update is posted from the KNX Bus to OH the time it occurs. so i cannot control how often that happens.
thanks for assistance!
Karsten
