AVM Fritz!Binding DECT 200 Error after Update to 2.2
in the logs:
2018-01-11 14:06:43.945 [ERROR] [b.binding.onkyo.internal.eiscp.Eiscp] - Event listener invoking error
java.lang.NumberFormatException: For input string: "N/"
	at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
	at java.lang.Integer.parseInt(Integer.java:580) [?:?]
	at org.openhab.binding.onkyo.handler.OnkyoHandler.statusUpdateReceived(OnkyoHandler.java:314) [196:org.openhab.binding.onkyo:2.0.0.201610231822]
	at org.openhab.binding.onkyo.internal.eiscp.Eiscp.waitStateMessages(Eiscp.java:459) [196:org.openhab.binding.onkyo:2.0.0.201610231822]
	at org.openhab.binding.onkyo.internal.eiscp.Eiscp.access$1(Eiscp.java:338) [196:org.openhab.binding.onkyo:2.0.0.201610231822]
	at org.openhab.binding.onkyo.internal.eiscp.Eiscp$DataListener.run(Eiscp.java:494) [196:org.openhab.binding.onkyo:2.0.0.201610231822]
2018-01-11 14:06:44.029 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel mode in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610020347 does not exist, please recreate the thing
2018-01-11 14:06:44.032 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610020347 does not exist, please recreate the thing
2018-01-11 14:06:44.034 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel device_locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610020347 does not exist, please recreate the thing
2018-01-11 14:06:44.039 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel mode in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610213970 does not exist, please recreate the thing
2018-01-11 14:06:44.041 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610213970 does not exist, please recreate the thing
2018-01-11 14:06:44.043 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel device_locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610213970 does not exist, please recreate the thing
2018-01-11 14:06:44.049 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel mode in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610214520 does not exist, please recreate the thing
2018-01-11 14:06:44.051 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610214520 does not exist, please recreate the thing
2018-01-11 14:06:44.052 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel device_locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610214520 does not exist, please recreate the thing
2018-01-11 14:06:44.062 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel mode in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610231769 does not exist, please recreate the thing
2018-01-11 14:06:44.064 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610231769 does not exist, please recreate the thing
2018-01-11 14:06:44.066 [WARN ] [.binding.avmfritz.handler.BoxHandler] - Channel device_locked in thing avmfritz:FRITZ_DECT_200:192_168_178_1:087610231769 does not exist, please recreate the thing
Its a simliar Problem like here
But im using four FRITZ DECT 200
Thx!
same here, i created this: Recreation/Refresh Things after Updates/Upgrades
you have to recreate your things if you want to get rid of the messages
