Max_G
(Max G)
January 5, 2023, 12:08am
#1
openHABian 3.3.0 on rPi4 with 4GB
I am trying to change the background colour based on the item state.
The item state can have 8 states; however, I can use the one state to catch the colour for them all. Basically, if the item state (which is numeric) is 7, show standard background colour, anythign else show orange-ish.
I use a template widget.
<div ng-style="{
'background-color': itemValue('spm_AC_Source_Status')=='7' ? '#223344' : '#ff8000'
class="template-container"
style="top:0;bottom:0;left:0;right:0;position:absolute">
<div class="template-contents">Grid</div>
</div>
However, it does not change the colour as expected. In fact, it is always orange.
Also, what formatting should a well-formed template take?
Should it look like what I posted above?
Any hints appreciated.
Should this be
'spm_AC_Source_Status.state'
Greets
Max_G
(Max G)
January 5, 2023, 9:05am
#3
Reading the doc says:
itemValue(name) - gets the value (state) of an item
I have another template w/o state which works.
Hmm… Maybe without the ’ at
='7'
Because number, not string?
Greets
Max_G
(Max G)
January 5, 2023, 10:31am
#5
Yep, tried that too… no difference.
The item exists and has the value 7:
Mark_VG
(Mark)
January 5, 2023, 10:47am
#6
The item state is a string, so should you not be using “7”
itemValue('spm_AC_Source_Status') === "7"
Max_G
(Max G)
January 5, 2023, 10:54am
#7
Hmm, why three equal signs?
Why double quotes?
Adopting your suggestion, actually makes the the background blueish, but does not change when I change the item state to 6.
I have this working:
<div ng-style="{
'background-color': itemValue('Shed_SLO_Door_External')=='OPEN' ? '#006622' : '#223344'
<div class="template-contents">Media room external door
<widget-icon iconset="'eclipse-smarthome-classic'" icon="'door'"
state="itemValue('Shed_SLO_Door_External')" size="80" center="true" />
</div>
</div>
Where my current template is a derivative from. I am puzzled.
Mark_VG
(Mark)
January 5, 2023, 11:17am
#8
From my understanding you could use == as well - === is a more strict comparison
“7” because 7 is a string
Max_G
(Max G)
January 5, 2023, 1:11pm
#9
Well, well…
While the item receives numbers, a map() changes it to strings, like AC Source is in tolerance
. Hence, after changing the second line to:
'background-color': itemValue('spm_AC_Source_Status')=='AC Source is in tolerance' ? '#223344' : '#ff8000'
The b!oody thing works
I apologise for ‘forgetting’ about this minor, yet very effective, oversight.
Thank you for wrecking your brains on this; at least I did.
