Backup to extrernal sd
Trying to backup to external sd using openhabian option 54 raw copy sd,but i get this error
Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card
FAILED (e2fsck)
/opt/openhabian/functions/helpers.bash: line 25: 94788 Segmentation fault      "$@" &> /dev/null
FAILED (set random UUID)
OK (dirty bit on fsck /dev/sda2 is normal)
2023-03-12_10:59:29_EET [openHABian] Checking for default openHABian username:password combination... OK
2023-03-12_10:59:29_EET [openHABian] We hope you got what you came for! See you again soon ;)
openhabian@openhabian:~ $
tested with many sdcards 32/64/128Gb,and 3 differend readers with the same result.Any ideas?
No. Segmentation fault means it’s a binary crashing that would not happen under normal conditions.
Could be anything, your hardware (the rest, not the new SD card) or your installation could be broken.
Your best bet is to reinstall your system.
i will do ,thnx
