I’m sorry that I have not contacted me so long. I did some tests for a few weeks. First of all, I wanted to test the following option:
It’s also very apparent the first time you fire a rule after saving a config file - the rules have to be reparsed and recompiled by openHAB. It will take some time to do that, and then it should run fast after the first time.
I experienced the same issues…
here is what I do to solve my problems (hope it helps):
It seems when you edit your rules or items file that openhab is a bit between two worlds (the old one with old values + the new one) so it may require some time to sync everything -> just restart openhab after your changes on rules and it should be fine.
So I tried to do the following:
Change configuration. Then go through and press all devices. After 5 days nothing change, control does not start new.
Change configuration. Then go through and press all devices. After that change 5 days nothing, control regularly start new ones.
Change configuration. After that, do not press anything. After that, do not change anything for 5 days. Control does not restart.
It got better, but the problem remained.
Can you post the items and rules involved, please?
It’s different switches and things. I have over 50 things, about 20-30 more. Slow is always when I press WALLC-S Wall Controller. In the log see that push arrives directly to controller without delay. Relay switches, either PAN06 In Wall Dual Relay (1 Way) Switch Module 2 x 1.5kW or FGR222 Roller Shutter 2. But it takes several seconds until the signal is sent and then it works fast too. Just the time between receiving the signal and sending the signal is the delay. You can also see that on the Log Screen, which I sent above.
18:04:08. 693 Signal incomming
18:04:20.510 Signal sending(Reactions time over 10 Seconds)
18: 04: 20.517 Get back status (again, everything fast)
So now parsing and compiling is only partially a problem, something else slows down the system.
