And I have it sitting in the home/openhabian/sitemaps directory (where the original yo program put it). I have an items file in home/openhabian/items defining the dimmer light:
I assume your running openHAB on a Pi with openHabian? Then I’m afraid, there was some error while installing it, because with openHABian there’s definitely another file structure…
/home/openhabian is empty (except the Linux files)
all configuration is /etc/openhab2/... (html,icons,items,persistance,rules,scripts,services,sitemaps,sounds,things,transform)
Did you do much with your Installation already? If not, you should try to install openHABian again (v1.4?)
binderth, yes, I am running on a Raspberry Pi 2 with openHabian. I wasn’t having a lot of luck with the other Linux distribution I was using, so I installed a fresh openHabian on a new SD card. I don’t have a lot setup, and I’m still trying to learn the system, so I could conceivably reinstall.
that would be the best solution at this Point. So you get a clean fresh install (you can still backup your configuration files and copy them later at the right Location).
binderth, I just did a fresh install and re-enrolled my bindings and things. I built new items and sitemaps files using very basic parameters below at directory /etc/openhab2/items and /etc/openhab2/sitemaps:
