I have to say that I investigate deeper and try to figure out what the issue is.
And after adding some more temperature values to the groupe, I saw that the other values are shown correctly and only the first one (Wohnzimmer_Temp), which I ever had before, have the described problem.
If I remove it from group, everything is shown correctly in x-axis.
Now I’m asking, what is wrong!?
All values are configured in same way:
2018-12-30 20:32:03.621 [vent.ItemStateChangedEvent] - FlurOG_Temp changed from 22.3 to 22.2
2018-12-30 20:32:04.369 [vent.ItemStateChangedEvent] - Wohnzimmer_Temp changed from 22.8 to 22.7
knx config:
Type number : Wohnzimmer_Temp "Temperature" [ ga="9.001:<5/5/60" ]
Type number : GastWC_Temp "Temperature" [ ga="9.001:<5/5/30" ]
Type number : FlurOG_Temp "Temperature" [ ga="9.001:<5/5/70" ]
I had some similiar problem here and never find the root cause.
A simple service restart resolved the issue.
I had this issue with homematic/weather items and the mysql persistence.
