I have several sting items in my OH configurations, which are linke to a channel of the http plugin. In items configuration menu as well as in the semantic Main UI the values are shown as expected.
In Basic UI this strings are not displayed. The Items simply added by Default item=PluggitBypassActualState but also Text item=PluggitBypassActualState has the same effect. I only see the label and the icon but not the items value.
I have the same problem with multiple string items linked with the http plugin. String items linked with channals from other plugins works.
What could be the problem and how to fix it?
I just updated to OH3.4 but I also hat the issue before.
Thanks for that hint, by adding label="LabelName [%s]" the string value get’s displayed. But finnaly i need to redefine the items label.
It’s somehow inconsistant. For other string items it works without that label, for this not. So it seems that is a workaround to “hide” the root cause of the issue.
Some bindings also set a default %s pattern on their (string) channel types, sone others don’t. If your problem is only with the HTTP binding, that would be something to check in this binding.
If no default pattern is defined by the binding for the channel, maybe you need to define a label with a %s pattern.
To be honnest, I have in mind that many years ago, I added code to have always a default pattern for string items, maybe this code was then removed.
By curiosity, did you try to set a label without a state pattern? Is the value displayed in that case?
