I updated from openHAB 3.3.0.SNAPSHOT → openHAB 3.4.0.M6 on a Windows 10 install. ( This was a fresh install not a Powershell update.)
Live updates no longer work on Basic UI . I have to manually refresh the page and they show the correct state. Any idea if there was something that changed with the new Milesone.
I have tried multiple browswers and same thing happens. Once I refresh the new status shows.
Same thing is happening on the OpenHAB-3.4.1 Stable Version.
Bummer…
Does anyone know if I want to try another install which folder/s do I need to backup and copy over. I want to keep persistence, system configs, added Items through UI, etc. Do I only need to copy over the conf and userdata folders ?
In the runtime\bin directory you should be able to find backup.bat and restore.bat.
Running them with the argument /? should print their usages.
This will backup the OH configuration, OH userdata and depending ( ! ) on which persistence service you use persistence data as well.
Backup is stored in a .zip file.
Create a backup and check it’s content by browsing through the zip file or listing its content so you can check if everything is included that you need.
