Hi all,
i have installed OH 2.3.0 Build 1272, from scratch on RP 3 (Rasbian strech, oracle java 1.8.0_65).
Then i have restore a older backup that works in the past fine.
Problem:
In BasicUI the sitemap property visibility partly not working.
Sitemap
Frame {
Slider item=Licht_KZ
Switch item=hue_1
Slider item=hue_1_Dimmer visibility=[hue_1==ON]
Colorpicker item=hue_1_Color visibility=[hue_1==ON]
Frame {
Switch item=KZ1Hide
Text label=" " icon="none" visibility=[KZ1Hide==ON]
Setpoint item=TempControl_KZ1_soll label="Solltemperatur [%.1f °C]" visibility=[KZ1Hide==ON] minValue=18 maxValue=25 step=0.5
Switch item=TempControl_KZ1_ label="heat control" mappings=[100="Auto",101="ON",102="OFF",103="-2°"] visibility=[KZ1Hide==ON]
Item definition
Switch KZ1Hide "more" <returnpipe> {expire="2m,command=OFF"}
Switch hue_1 "hue 1" {channel="hue:0200:1:1:color" }
In the first Frame with item hue_1 the slider and colorpicker are visible then hue_1 is ON. But it takes same seconds.
In the second frame with switch item KZ1Hide the following text, setpoint and switch items are only visible then browser tab manuell refreshed.
The same configuartion in the classic UI works well.
Thanks for help.
