it seems that the basicui ist not responsive, meaning that updates on e.g. status, values, etc. are not updated? do you see the same thing?
An example:
When i change a value in basicui (e.g. a heating thermostat) the value is changed correctly at the hardware thermostat, but when i change the value directly at the thermostat, the value is not updated in the ui.
basicui is responsive for me, i did not wait long enough due to the max thermostats are quite slow to transmit the data to openhab, sometimes it takes up to 1 minute.
